Striker187
- 2008 MS3 GT
well i'm glad to know that nothing's wrong with my computer. i'll have to listen to them when i get home from work.
Striker187 said:man i dunno what you people are talking about. the o2 sensor is in the right place.....before the 2nd cat. you can clearly see the o2 sensor placed right after the flexpipe section but before the 2nd cat. you're fine rainman (2thumbs)
Striker187 said:i retract my previous statement. driving home, i was thinking about your setup and i realized blkzoomzoom is right. (doh) the cat should have been before the 2nd o2 sensor. why you haven't thrown a cel yet, i have no clue.
Rainman said:I asked the exhaust guy about this before I replied. I also checked the MSP specs (www.autocoast.com/mazdaspeedclub/03.5_mazdaspeed_specs.pdf) just to double check what he was saying. He said that he placed the O2 sensor in the same relative position as it was on the original system. I will post pics to show you what I am talking about.
He told me that there was ony a single cat on our system. I had thought that there were 2 so I checked it out myself. The other "cat" is not actually that, but rather a resonator. That is why the volume of your exhaust goes up markedly if you get rid of it, such as with a cat-less downpipe. On my system, he eliminated the resonator for increased flow and then put the cat and the O2 sensor in the same orientation as he found them on the stock system. He also said that it was not possible (or at least not a good idea) to move the cat or the O2 sensor from where the were originally intended to be for the reason of the dreaded CEL as you suggest. So no CEL because the system is designed like the original--less the resonator. The MSP specs state that we have only a single cat on our exhaust system. The resonator is there primarily for exhaust note and volume. Believe me, the exhaust is a hell of a lot louder now than it was stock! My wife likens it to a truck exhaust...LOL! In the pics that I will post tomorrow, you can see that on the stock exhaust the resonator and cat look different and the O2 sensor is before the cat in order to provide info on pre-treated exhaust gases.
Hang tight until I post the pics tomorrow.
wicked said:by the way he did a good job on your setup.quality work.
Rainman said:Just got my custom exhaust finished for a local show last week. Got some attention at the show, but with it being my first show and only a few mods, I didn't end up placing in the Protege class.
Anyway, I had a s-pipe back 3" aluminized steel, CRUSH-bent, over axle exhaust built with a single catalytic converter and a Magnaflow muffler. The car is more reactive now and the remaining post-flash hesitation is just about gone. I tried to get a muffler that looked close to the stock, but then I ended up picking one with a 4" round opening as it had bevelled edges which looked very clean. I love the sound that it makes, although it is a bit loud for my wife. On the highway cruising at 180 km/h it sounds great.
I know that for most people aluminized steel and crush bends are taboo, but for the money ($450 CAN, all parts and labour) I think that I did alright. I have only heard 1-2 backfires after driving it all week in various different types of situations (city, highway, idling, etc.).
I will post some movie clips and pix when I have time to take them. I await the flames for my crossover to the aluminized crush-bent darkside of the MSP force.
armando_026 said:Not sure on this but here is my best guess on why you only have one cat,it is because you are in canada. MSPs in the states have two.
Don't quote me on this. Like I said this is just my best guess. (uhm)
tekkie said:all MSP's have 2 cats including the Canadian ones
thunder said:Since I've been reading here and there on this forum about the 2nd cat, which looks like a cat but some say it isn't, I went and took a good look at the pipe with these two piece since I've taken them off a while ago. Well, if it's not a cat then I've no idea of what this is! It's not straight through that's for sure and definitevely has a honeycomb pattern all the way through, just like a cat. Conclusion: all MSP (Canada and US) have two cats. Why? No idea, all I know is that the Impreza has even three so two shouldn't be too surprising....
Rainman said:If this is true then the O2 sensor would be in the correct spot for our single cat system since it would provide rich/lean info about the untreated exhaust gases to the ECU.
Rainman said:Now if we could just get a Mazdaspeed technician to add their $0.02, we could finally lay this dog to rest....LOL! (help)
Rainam
gboromsp said:Looks good, but dang your car is dirty underneath. I guess winter has affected yours a lot. I think I could eat off of mine. LOL
C-Bass said:That is what your FIRST O2 sensor does. The second O2 sensor (the one in question here) checks the exhaust gasses after passing through the first cat to see if the converter is doing it's job. If there is indeed only one cat in the exhaust system, it's the cat-like structure BEFORE the O2 sensor, not after it.
You basically have 2 O2 sensors measuring the same thing in your setup.
Rainman said:Also, if the 2nd O2 sensor checks that the first is doing it's job and the cat is after the 2nd in my case (my exhaust is apparently downpipe-flexpipe-O2 sensor-cat-exhaust without resonator-muffler) then my car should read that the cat is NOT doing its job and then I should get a CEL.....which I am not. Why?
