ZoomRedZoomGT
- Mazdaspeed 3 Red 07' GT
By the way...once this is on should the computer be reset? If so how long does the battery have to be disconnected for it to reset?
dread said:oh man, and I wanted to wait for dyno's. I may be in on this one, I will let you know, awesome deal captain. Hopefully someone will get a dyno done asap.
Speedy3 said:Dyno coming tomorrow. Actually, I can tell you the % gain in 3rd and 4th gear. 1st and 2nd will have to wait for the rain to stop here; too much slippage and 5th and 6th are too fast for me to test. If you all are wondering, I use Auterra Dyno-Scan SW for the Dyno test.
I ran 6 runs today before installing the CAI. Mean values are:
3rd Gear: 224 HP @ 5300 RPM, 238.8 ft lbs @ 4233 RPM
4th Gear: 253 HP @ 5500 RPM, 255.8 ft lbs @ 4333 RPM
These numbers represent the power and torque at the wheels. The value to focus on will be the % difference from the stock numbers to the numbers I get tomorrow with the CAI installed.
Numbers with MS CAI to come tomorrow, Saturday, 3-2-2007.
I installed my MazdaSpeed CAI today and man, it makes a very noticable difference. The car pulls harder in lower RPMs now and third gear now loses traction on wet pavement whereas it didn't before. I didn't have time today to test the poer/torque with the CAI caus I already got crap from the wife for taking 2 hours to get the baseline numbers above and 2 hours to install the CAI. I had to drive out towards Mt. Rainier to do the test runs. No traffic out there.
I will also try and post intake manifold temperature differences from stock to upgraded with MS CAI.
Speedy3 said:Ok, got it! I ran 3 runs in 3rd gear WITH the MazdaSpeed CAI. Here are my results (Mean values of 3 runs each):
Stock
3rd Gear: 224.0 HP @ 5300 RPM, 238.8 ft-lbs @ 4233 RPM
With MS CAI
3rd Gear: 247.5 HP @ 5200 RPM, 273.0 ft-lbs @ 4267 RPM
The gains
HP: 10%
Torque: 14.3%
Based on Mazda's baseline figures of 263 HP @ 280 ft-lbs Torque, the new numbers should reflect my measured gains and would be 290.5 HP @ 320.1 ft-lbs of Torque!!! That is a gain of 27.5 HP and 20.1 ft-lbs of Torque!
I will do more tests when it dries out here and try doing it in all gears. BTW, I only took measurements without wheel spin. In some cases, I had to feather the throttle to prevent it.
dread said:You do not have to remove the bumper but it makes it easier. Those are really good gains, I wonder what forth looks like. How much variation to you see between runs.
BSTD3 said:Speedy3:
Those numbers look real promising. Dumb ? but did you have to remove the front bumper to install the MS CAI? I'm not shy to take things apart as I did the same thing on my RX-8 to install some lower grills.
TIA.
Stock
With MS CAI
The gains
HP: 10%
Torque: 14.3%
Speedy3 said:The numbers varried from the mean by +/-:
Stock:
HP: 2.3%
Torque: 5.6%
With MS CAI:
HP: 7.5%
Torque: 11.3%
I believe, the higher variation in the MS CAI test is due to too much tire slippage. I will re-do the runs today if I can.
dread said:Those results seem too good to be true, how accurate are those things? I want that intake bad.
Captain KRM P5 said:all sold out![]()
BSTD3 said:CRAPOLA!
