Gauge Works Full Pillar Pods are shipping
Voltage = The Voltage that your getting from the Alternator/Battery... good to know if you have a sound system in your car.... the higher the voltage the more power your getting to your system...
EGT = ???????????
Oil Pressure sounds good though....
yeah so boost and oil pressure, and voltage??? nah i don't need voltage i dont plan on altering the stock msp sound system. its all i need or ever want i usda have a system but i got bored with it after awhile.
i would go with Boost, Oil Pressure and Air/Fuel Ratio then... unless you only want the dual pod and not the triple....
still dont know what EGT is...
so air to fuel is good to know if you have a emanage system which i plan on getting eventually. so i guess ill go boost oil pressure and a/f r
thanks a million cheese :)
Exhaust Gas Temperature Guage......
for those of you running higher than average boost.... With a good EGT, you can see if you are running too rich or too lean based on the exhaust gases temperature
At Wide Open Throtle.
paulmp3 said:
What kind of paint are you using to match the interior? This is a full replacement pilllar right?
No it's not a full replacement, jsut a cover to go over your stock one.
