Talrum said:I am planning on getting Boost/Vac, A/F, EGT..... going to put them on an A pillar. Where is Ogden?
Maxx Mazda said:You can install that s*** yourself man, it'll take you like 6 hours at the very most.
Rudy23 said:Temple of Torque
3-2808 Ogden Rd SE, Calgary, AB T2G 4R7
(403) 265-6669
(403) 265-6696 (fax)
www.templeoftorque.com
Talrum said:I ahve no idea how to do this type of stuff, and i dont wanna screw up my car. I installed my CAI and SMIC, but those were jsut more or less dropins.
Talrum said:Thanks for the info, i will give them a call. Do you know how much they would possably charge for this type of install?
Maxx Mazda said:Ya Talrum, if you want some help, I could save you a shitload of dough...
Talrum said:I would really appreciate that. So you've done the boost, A/F, and EGT before?
I will might go get the guages from MOPAC tommorrow. Thanks
Maxx Mazda said:Did Mechanical Boost and EGT on a Tahoe at work. (Helped put a magnacharger on it) wasn't hard at all. EGT will require some welding though, but only wnough that a good welding shop should only charge you like $10 and 45 seconds worth of labor.
el chilenito said:i got mine installed at auto dream in the NE.
Talrum said:Is mechanical boost more accurate than electronic? I am waiting for an exhaust sytem which maye take another few months, it requires the extebnsion of the stock O2 sensor so i guess the EGT will have to be redone again when i get eh exhaust.
I have heard that it is more accurate to have the EGT sensor before the downpipe in the exhaust manifold or somthing, but it is more dangerous. SI this true?
thanx for your help.
Rudy23 said:Welcome to the Board, El Chilenito!
