To answer everyones question about the fuel cut, Yes the PCM will cut the fuel if it see's a over boost. The problem is that it doesn't say what boost level it cut's the fuel at. I assume that if it cut's the fuel at some point the engine has been tested to make sure that it's the safest boost level the stock engine can handel. This info is directly from MAZDA and can be found in the 2003 service highlight manual. If 12 psi doesn't make the PCM cut boost then in my opinion that's not the peak safe boost.
