FS-ZE cams
suttonschinook
Potential Scammer!
I just got my cams from Corksport and I need to know which one is intake and which one is exhaust. Also one of them has two holes for the dowel, which one do I use? I just ordered a G-tech so I will wait to install them until I can run the car with it stock. I get the hp and tq from that and then with the cams. I hope I get a decent increase in power. I'll post the results when I have them.
They can't void my warranty just because I put aftermarket parts on. If for some reason something breaks and they prove what ever part or parts I put on caused the problem then they can void my warranty for that part.
Warranty
That is right they are not supposed to void it unless they can prove it. I have already had a little talk with my dealership. They had thought i had put Denso plugs in my car when they came stock like that....
haha i wish i could void my warranty! lol cams will void alot of stuff and it is the other way around they WILL void it and then you have to prove them wrong
The Mazdaspeed exhaust cam has a Green mark on it. They are both marked intake because the Exhaust Mazdaspeed Exhaust cam is ground from a FS-ZE intake cam. The Ex cam is not from teh FS-ZE it is from a limited production Mazdaspeed protege in Japan that made 170ps (bout170hp) normally aspirated...it also had a lightweight flywheel, header and different clutch I believe I could be wrong on the clutch. Anyways just thought I woudl clear that up since thats what this thread was abotu to begin with.
Also, parts that are replaced without being payed for under warranty, i.e. spark plugs, spark plug wires, air filters, and so on cannot void your warranty. I believe that is also under that same act.
