FS: Walbro, RC750cc, P5 diff., Longblock (local) & more
Have a few things to clear out...
PARTS ADDED 9/3/10 Hiboost Mani&DP, P5 Radiator, Radiator Cover Thingy
MORE PARTS ADDED 10/12/10 Stock P5 Intake System, Stock fans
1. Walbro GSS342 about 2k miles perfect condition $80+shipping SOLD
2. RC750cc Injectors Purchased from another member but never installed due to the owner not realizing I needed to cut my harness. Sold to me
3. Power steering pump $30+shipping SOLD
4. Slave cylinder $10+shipping SOLD
5. Oil Pans $25+shipping SOLD
6. Protege Fuel Rail W/ Line and FPR $35+shipping
7. Protege Fuel Rail $20+shipping
8. P5 Strut Bar $20+shipping SOLD
9. P5 Struts 10k miles still like new (FREE P5 springs) $100+shipping SOLD
10. Open Differential w/spider gears one with speedo gear and good bearings and one without $40+shipping each
11. P5 Rear Swaybar w/ endlinks no bushings or brackets $20+shipping
12. P5 Front Endlinks $20+shipping SOLD
13. FS Longblock Stock 90k miles no holes 190psi acrossed all cylinders but burned about 1/2qt every 3k miles no timing belt, upper timing cover, vc or oil pan $500 SOLD
Added Items
14. Hiboost Turbo mani and 2.5" dp with seized turbo due to 22psi and no coolant lines hooked up (Turbo is IHI VF-22 for replacement) I loved this set-up and is very comparable to my T25 GT3071 but boost kicks in a little sooner and holds very steady. $175+shipping SOLD
15. P5 Radiator no leaks $75+shipping
16. DIY Radiator cover thingy $25+shipping
17.Thunder Mani Project (welded several times...pics worth 1000 words) $120+shipping SOLD
17. Stock Intake System $50+shipping
18. P5 Roof Rack $80+shipping SOLD
19. P5 Cooling fans $25+shipping each
No Dibs
No Shipping to Canada SORRY!
Paypal to P5TShane@yahoo.com
absolutely one of the best manifolds ever produced for the MSP - and from what ive read, the IHI turbos are PERFECT for 2.0L's. too bad theyre such an impossible sell - WAY cheaper than garrett with all the capacity.
bump for you!
Crap I'll let you know in the morning. Just got my pope dp and boost activated cutout in and had a random chain reaction of problems to follow. All is more than fine now :)
Okay dude so the hole for the cap doesn't line up with my cs radiator so if you can take a measurement going across the radiator bracket threaded posts that are sticking up for the stock intake system. From the drivers side bracket straight over the threaded post what are the x and y dimensions to the center of the radiator cap. I measure on my plate x=8" y=.5"
I have someone very interested but he is dealing with a blown tranny unexpectedly. Let me send him a pm to see if his plans have changed. Just so you know this is from the standard kit and not the bigboost t3. I ran 22psi on an ihi vf22 and I could pull my bosses 08 z06 in any gear except 1st :)
I'll let you know something by tomorrow in the am.
hiboost manifold and dp are still available?...
To avoid confusion this is the set-up I ran... Intake piping was the original Hiboost Kit and has been sold to another member.
But in their revised kits they simply ran a 180* silicone coupling to the inlet of the turbo and by relocating the coolant overflow ran piping back over the turbo with a similar heatshield between to the air filter on the drivers side. I planned on a diy ram air hood with a cartridge filter in the near center of the hood but ended up going to a slightly bigger set-up. I ran 22psi with this set-up with an IHI VF-22 and put down around 330-350whp.
attachment.php
attachment.php
