FS: Walbro, RC750cc, P5 diff., Longblock (local) & more
Have a few things to clear out...
PARTS ADDED 9/3/10 Hiboost Mani&DP, P5 Radiator, Radiator Cover Thingy
MORE PARTS ADDED 10/12/10 Stock P5 Intake System, Stock fans
1. Walbro GSS342 about 2k miles perfect condition $80+shipping SOLD
2. RC750cc Injectors Purchased from another member but never installed due to the owner not realizing I needed to cut my harness. Sold to me
3. Power steering pump $30+shipping SOLD
4. Slave cylinder $10+shipping SOLD
5. Oil Pans $25+shipping SOLD
6. Protege Fuel Rail W/ Line and FPR $35+shipping
7. Protege Fuel Rail $20+shipping
8. P5 Strut Bar $20+shipping SOLD
9. P5 Struts 10k miles still like new (FREE P5 springs) $100+shipping SOLD
10. Open Differential w/spider gears one with speedo gear and good bearings and one without $40+shipping each
11. P5 Rear Swaybar w/ endlinks no bushings or brackets $20+shipping
12. P5 Front Endlinks $20+shipping SOLD
13. FS Longblock Stock 90k miles no holes 190psi acrossed all cylinders but burned about 1/2qt every 3k miles no timing belt, upper timing cover, vc or oil pan $500 SOLD
Added Items
14. Hiboost Turbo mani and 2.5" dp with seized turbo due to 22psi and no coolant lines hooked up (Turbo is IHI VF-22 for replacement) I loved this set-up and is very comparable to my T25 GT3071 but boost kicks in a little sooner and holds very steady. $175+shipping SOLD
15. P5 Radiator no leaks $75+shipping
16. DIY Radiator cover thingy $25+shipping
17.Thunder Mani Project (welded several times...pics worth 1000 words) $120+shipping SOLD
17. Stock Intake System $50+shipping
18. P5 Roof Rack $80+shipping SOLD
19. P5 Cooling fans $25+shipping each
No Dibs
No Shipping to Canada SORRY!
Paypal to P5TShane@yahoo.com
Since I'm sure I wouldn't be able to sell the mani without the dp I could do the whole thing for $125+shipping minus the wga...I'm going to make a 3" boost activated cutout with that.
What do you mean by Thunder Mani Project....sorry can't see the pics here at work.
Unfortunately it cracked between the two middle runners time and again at 20psi. Re-welded several times later but with the amount of boost I run it just kept cracking right next to the same spot. I think it can be ground down and cut out a bit to weld a small plate in there versus a big averlapped blob of weld retaining all the heat.
Damn....you P5 guys boosting.....for whatever reason I was thinking NA.....(hand)
The Hiboost mani and dp are bullet proof on the other hand and I saw a replacement turbo on ebay out of a 07 STI IHI VF43 went for $355 and spools and puts out close to the same as my t25 gt3071.
is the thunder mani usable as is? or does it need to be fixed again? I'm only running 12 psi so not
worried too much as long as it's sealed right now.
Bump I know somebody wants a fullsize P5 radiator!!
Hiboost Mani and Dp needs replacement IHI Turbo (these are some that can be used and found cheap WRX and STI upgrades and oem) Vf-22, VF-34, VF-39, VF-43, VF-48
