Front Sway Bar Bushing Replacement
Im starting to get some front end noise and I believe it to be my sway bar bushings.
FSM says the sub frame needs to be dropped in order to replace. I know other Mazda models call for the same procedure but people are able to gain access without removing the sub frame.
Has anyone attempted this on their CX-5?
You don’t need to drop the crossmember but it would be easier to work on the car if you could lift it on the hoist. I i had to drop the crossmember only to replace the steering rack and had the transmission jack underneath to hold it.
