shaneMazda2000P said:thats kool, i was just sayin in genral terms, most people use and abuse them hence killin the motor and turbos..
Right. And hey, sorry if I came off rude. I'm guess I'm just a bit defensive
shaneMazda2000P said:signal, got any pics of your car, i wanna see it, i always liked the rx7s like urs...
shaneMazda2000P said:sexy... pure sexy.. but whats that on the headlight..
Beautiful! I'll take it.Signal 2 said:I'm not much of a photographer. These were for insurance. Pretty stock...and boring to most. But I like it.
Familia323 said:Beautiful! I'll take it.
Alak said:Do a compression check and post the numbers. That determines how well the engine has been treated. Remove the CAS (aka Distributor) and check for residue on the stem. If all is well, beat on it until it goes. Then build a better one.
Alak said:Compression Check: Pull out spark plug and do a compression check as you would a piston engine.... Distributor: Its called a CAS (Crank Angle Sensor). Its like a wireless distributor...
In all seriousness... WhyTF are you talking about this s***? (poke)Alak said:A Blown rotary will still run. It will get you too and from work. Heck it will even run with low compression on a non-blown motor. You do a compression check to see how strong the motor is. If it ever breaks down, thats rotary 101. Compression check is the first step. 60PSI a Face (3 faces a rotor remember) is weak. 90PSI+ per rotor face is strong. Over 100PSI and its VERY strong.
