Footrest mod.
2022 2.5GT
Im absolutely convinced that the carpet will wear out on the footrest before long so a strip of rubber matting off eBay, stuck at the bottom with tape and underneath with velcro;
I like it !!! Looking on doing the same. Do you have a link on where you found the material?
I have something similar for the winter months when I pull the ebay aluminum footrest off. I used a rubber stair tread from homedepot and cut it to fit. the stair tread has an edge on it 90 degrees to the rest so there is a little over hang to better protect the carpet area. hope that makes sense
I’m absolutely convinced that the carpet will wear out on the footrest before long so a strip of rubber matting off eBay, stuck at the bottom with tape and underneath with velcro;
Thanks Anchorman, Just found the exact same "non slip stickers" in a local shop and applied it with Velcro. Looks good and will probably outlast the vehicle.
I cut mine from a used old rubber floor mat and put velco on the back. It has been there for almost a year and is doing great. Cost me nothing because I had velco from an old foot splint my wife needed when she broke her ankle.
