phunky.buddha
Booga Booga?
- DFW TX
- No mo MZ5 want MX5
Camber isn't what wears tires the most- it's excessive scrub from lots of toe. For the best wear (not necessarily the best handling) you want your toe to be a close to zero when the car is in motion. For front wheel drive cars, that usually means a bit of toe in on the rear (positive numbers) and a bit of toe out on the front (negative numbers). When in motion, you car has dynamic toe that's different from static (driven wheels want to pull forward and toe in, passive wheels want to drag backwards and toe out), so your static toe settings should be set up with that in mind- except you can't measure your toe change while in motion, so you have to make a best guess based on your experience with the car and the manufacturer recommended settings to get the balance you want. Those settings will make your tires wear the best, but will make the car feel like it's all over the road- so you'll probably want to do follow the factory recommended settings fairly closely and back off the toe as much as possible (as much as you think you can stand) in the rear.
Here are the factory specs:
Front camber = -1.7 to 0.3 degrees, median = -0.7 degrees (not adjustable from factory)
Front caster = 2.0 to 4.0 degrees, median = 3.0 degrees (not adjustable from factory)
Front toe = -0.09 to 0.28 degrees, median = 0.095 degrees
Rear camber = -0.3 to -2.3 degrees, median = -1.3 degrees (not adjustable from factory)
Rear toe = 0.00 to 0.23 degrees, median = 0.115 degrees
Right now I'm running:
Front camber = -1.4 degrees
Front caster = 3.4 degrees left, 2.9 degrees right (should make it pull right, not adjustable on my car)
Front toe = 0.00 degrees
Rear camber = -1.7 degrees
Rear toe = 0.02 degrees each side
The car is fairly neutral, but it wanders left/right depending on the road surface and tilt if I take my hand off the wheel. Car manufacturers don't want that because it's not considered to be safe to average Joe Schmoe, but it's perfect for me- the response is a lot quicker with an aggressive alignment! If you're worried about tire wear but you still want an easy handling car, you can probably get a little aggressive on the toe, but don't go down to zero like I did- maybe stay around the 0.05 area at most with a little less in front.
