since I also own a BMW, it amazes me how I really don't experience many issues with my CX-9. the BMW is a high maintenance drama queen, whereas my Mazda is the always reliable, easily overlooked wallflower. anyway...
my power window developed a 'grinding' sound and wouldn't go up all the way without pulling on the window. usually, this means time for a new regulator and motor assembly. so I started researching it and found that it's usually a gear inside the motor assembly that fails, not the motor or track!
these gears are readily available on ebay.
youtube videos show it should be easy to open the case to get to the gear; I had some difficulty with this and cracked the 3 mounting ears off. so after replacing the gear I super glued them back on. seems to be fine.
the door and window assembly seems to be designed to be easy to service. after doing this job in about an hour, I can say I like my mazda even more now
