Just bought my wife a used 2019 CX-5 Touring with 95K miles and my daughter a 2016 CX-5 Sport with 108K miles. Despite both having regular 5K or 6K oil changes neither have ever had the tranny serviced. Yeah, I know, can of worms here, but after owning many Asian cars, I am convinced that you gotta get fresh fluid in there regardless of when you buy it. It has worked for me so far. Anyhow, did the 2016 a few days ago. Just a drain and fill. I'll wait 25-30K before I drop the pan and replace the strainer/filter. Just figured, I need to get some old ATF out and new in. Went as expected. Observation No 1: The factory fill was RED, not FZ BLUE. Question: do they use FZ factory-fill that isn't dyed blue? I wonder why? Observation No. 2: I have never seen a bolted in dipstick! Why, Mazda? Is it so high pressure in the case the dipstick might blow out if not secured by a bolt? Observation No. 3: FZ is thin compared to most red ATF's I have used i the past Very runny for sure. Sure is a pretty blue! I guess to cut down on internal pump friction, they used the FZ with its low viscosity? At least I can get a trans kit with a rubber gasket for the 2016. I have never used RTV except to dab the corners on my old Mazda powered Ford Escort's valve cover and don't trust myself to use the RTV properly on the CX-5's trans pan.
Will do my wife's 2019 soon. Just drain and fill as well. Unfortunately there are ZERO Mazda specialty independent shops in Bham, AL area so the STEALERSHIP is the only option. I hate to find out what they want to charge me to drop the pan and service the transmission. I haven't found a rubber gasket yet for the 2018 and up cylinder deactivation 2.5's. The trans pans changed slightly from what others have posted.
Anyway, got some fresh blue juice in the slushbox so we are good to go for a while! Carry on!
