2007~2015 CX-9 Transmission drain/fill, only a single drain plug (no inner/outer)?
<div class="bbWrapper">Does anyone know if any of the first gen CX9&#039;s came without an inner/outer drain plug setup? <br /> <br /> Just bought my &#039;09 in July and started getting some shudder in gears 4-6 between 1,500 - 2K RPM in late October.<br /> <br /> Just drained and getting to refill, but found I only had a single (T40) plug<br /> <br /> I can&#039;t quite get all the way under the car, but can see enough to tell the drain plug came right out of the main body<br /> <br /> Also confirmed the expected 17mm hex doesn&#039;t fit where I pulled the T40 plug out of, not sure if I&#039;m being a dummy (this would not be unusual) and just missing something, or if I&#039;ve got a different setup on my new to me ride</div>
<div class="bbWrapper">Is this an automatic or a manual?<br /> The manual should have two plugs, a drain and a fill. The automatic will have a drain plug on the pan, then you fill it through the dipstick tube.<br /> <br /> I&#039;ve never seen a Mazda with a Torx drain plug though. Every plug I&#039;ve ever seen has been a regular hex head (like a bolt) or an Allen.<br /> <br /> Post a pic of what you&#039;re looking at so we can make sure you&#039;re on the right thing. You do NOT want to back out the wrong thing!!!</div>
