1) you might want to have that o2 sensor hooked up.. that might be my best guess as to your problem, but maybe not, but i think it might be.methodical_4u said:yeah, that EGR tube was another thing not even mentioned in the instructions. Someone had told me that I could just put a filter on the end of it and leave it. Plus the other o2 sensor is hooked up, but it's just hanging there. If I want to put that into the manifold i'll have to drill and tap it out, the primary is hooked up however. As for the injectors there are 4 brown wires that go to them, none of them labeled and of course 4 wires from the injectors not labeled either so I have one from each of the injector plugs grounded and the other 2 hooked to the brown wires. Does that sound right? This project is beginning to be more trouble then it's worth. Also, I am guessing this is sort of like any other valve, but does the blow off screw have to be turned clockwise or counter clockwise to increase boost?
2) the BOV does not control boost
