Tanginamo425
AAAAHHHH!!!!!
- Mazda MP3, Laser Blue Mica
Ok just wanted to know if anyone had a similar problem with their engines. I currently have about 55,000 miles on the car when the squeaking started to happen. Doesn't do it when it is cold but when it is warm it makes the sound between 2000rpm to about 2200rpm only when there is load on the crank. I thought it was the belts but they all check out. Yes I do my oil changes every 3000 miles as well. But it sounds like metal rubbing on metal, but after 2200rpms it disappears and runs fine. Again, the car itself runs fine but dunno what is making that noise....
