coolant odor present
I believe the culprit just might have been found, Mazda sent their regional guy out last tuesday, we all drove in it (3) around town for 10-15 minutes and stopped, I pulled the hood (outside temp was 60-65 degrees) and the smell was evident up by the radiator.
They kept the car for four days, replaced radiator and hoses, even pressure tested the rad, well I have had the car since then (6 days) and haven't noticed the odor. I sure hope sharing this doesn't jinx it!
Anyone who has read all the posts I have done-knows what a pain this has been. I think that the radiator core (aluminum) when glued to the plastic tanks, gets the right temp/pressure and lets just enough out to cause the odor in slow traffic/ in the garage overnight/ etc.
I talked with Griffin radiator years ago, they had a similar problem (racing radiators). I mentioned that at the beginning, but pressure testing didn't show anything, that is why I say the right temp/pressure causes a pin hole to open up, and that is possible with epoxy/aluminum/plastic bond. expansion/contraction.
I highly doubt anyone could challenge this result, and don't care as long as the problem stays away. it has been this way since new (18 months ago)
Kudo's for Mazda if this works, you have to get the service manager to witness it and forward the story, otherwise you'll just get the "could not duplicate symptoms" line, which is a cop out for lazy service team.
good luck,
D
