WetsuitxNinja
- Mz3
I could get mine to do it when it was in neutral. It was more pronounced when I was in 2nd and 3rd gears at the same RPMs.
Rac3rX said:I used to get the sound too, only under load in gear, but never at a stop.
To be safe and sure it wasnt because of low or Bad oil, I did a change and the sound was still there, then I installed the 4 - 1 headers that did 2 things. 1 it added a header gasket, and 2 it removed the heat sheild from under the car.
I havnt heard it since then
Moonman8 said:I've got a Thunder header on the way thanks to Protephile's GB so maybe my little rattle will go away!
Rac3rX said:I hope so, Im not quite sure what was causing it, it was annoying as Hell.
the stock gasket on the exhaust manifold is a joke its just Couple of thin peices of steel, and I mean thin especially compared to the gasket I got with the Tsudo headers.
I left them there BTW and just put the gasket that came with the headers right over it.
The sound came only under load in gear never at a stop, so Im geussing it has to do with the heat sheild, a good way to test would be to remove it (You have to anyways when you install the headers) this should be a good way to test if its the heat sheild.
Give it a shot remove the heat sheild (3 bolts 5min) see if it goes away.
WetsuitxNinja said:I had the obx header when mine was making the sound, did it when I put everything back to stock too. Both dealerships I went to said it was normal. weird
WetsuitxNinja said:#1 reason I traded the p5 in. Dealership said they couldnt hear it, then when they did it was because it was starved of oil. Traded it in a few weeks later at a different dealership. There are probably a dozen threads on it. =(
Rac3rX said:How did the engine get starved of oil?
I just put in some oil detergent (for engines) In, Im running her for 100 to 250klm then flushing the engine with a engine flusher, and after that new oil and injector cleaner.
Rac3rX said:The downloads dont work
