- 2002 Mazda Protege5
Problem Solved (07/06/2014)
The right side Ignition Coil was failing. It was a cheaper after market coil I purchased from Autozone, so I guess I learned today you get what you pay for.
Hey everyone,
So I've got a problem with my Protege5 and it may prevent me from getting home... which is two and half hours of driving.
Problem
My car completely stalls and shuts down. When the car is idling at a traffic light it just randomly shakes profusely and follows up by shutting down. When I drive it randomly starts to shake and the car feels like it's having a tough time keeping a consistent pace. Sometimes it will misfire as well.
Car Details
2002 Mazda Protege5
Mileage: 57,170 Miles
Automatic
Troubleshooting Taken
(This section will indicate everything that has been done to fix this problem, but the problem still persists)
1. Replaced Ignition Coils/Wire-set & Spark Plugs 7,000 miles ago.
2. Cleaned Throttle Body and dealership reset "Throttle Sensor"
3. Replaced both engine belts around 5,000 miles ago
4. Replaced EGR Valve with brand new valve today. (7/03/2014)
5. Replaced PVC Valve about 5,000 miles ago
6. Replaced Air Filter about 5,000 miles ago
7. Replaced engine Transmission and Engine oil about 5,000 miles ago
8. Replaced battery terminals and cables today. (7/03/2014)
9. Fuel Induction Cleaning today. (7/03/2014)
10. Reset "throttle body" sensor.
11. Replaced Air Intake Tube about 3,000 miles ago.
Explanation
I've always had subtle issues with this protege misfiring, but that was completely fixed by replacing the ignition coils and spark plugs. This issue started happening at random about 2 weeks ago. I would be driving and it would shake violently and feel like it's about to stall at least 2 -3 times, sometimes more, during any given trip. Yesterday during my two and half hours of driving to my families home the car struggled at least 5 times where the engine would randomly jolt and at one point the engine completely misfired. So I went ahead and bought a new EGR valve and gasket and installed it, thinking this would solve all of my issues. Well I was driving around and the car was really struggling to get above 2,000 rpm after I installed the EGR valve and then the engine completely stalled and shut down. So I drive straight to a Mazda dealership. They said the error codes that displayed indicated the positive and negative wires on the battery were bad, "which would explain why it was having a difficult time gaining speed" and they also stated the fact that I've cleaned the Throttle Body, with some normal run of the mill Throttle Body cleaner from Autozone, and did not reset some Throttle sensor was most likely causing too much air to flow through and causing the engine to jolt, choke, stall, shut down, whatever term you want to use. Well they "fixed" those issues and right as I was about to pull off the dealership lot the car shook profusely and then shutdown. The mechanic that worked on it got in and when he was messing around with it and the car stalled and shutdown again.
So they took the car back into the shop and 30 minutes later came out and said "We don't know what's wrong with your car and we are closing. Sorry about your luck but we aren't going to be around Friday or the weekend for the 4th of July Holiday." So the guy basically said sorry but we can't fix your issue and good luck getting home. We wont be around until next week.
I drove the car home and it literally had NO issue getting back home. No jolt, no stall, no struggle. But then when I started the car up in the parking lot of my parents home I had the car in Drive, and with my foot on the break, and not even 2 minutes go by and the car shuts down. I thought "maybe when the AC is turned on is what is causing this issue" but the car still stalls and shutdowns with the AC off. So I literally can't think of what the issue is. Not even the Mazda Dealer Mechanic knew what was going on nor did he want to wait around much longer to continue troubleshooting it...
Can anyway else offer advice as to what else is possibly wrong? I literally can't think of what else is causing this issue. I don't think it's the air compressor.. but who knows. I would rather avoid having to deal with this, drive home, and have the car potentially stall and (worse) break down again. That's already happened once and I was forced to stay at a $40 motel next to the mechanic shop.. that was hell.
Hey everyone,
Problem
Car Details
2002 Mazda Protege5
Automatic
Explanation
