Emblems Removed
i did a temporary fix when i removed my badges by using some vinyl on the inside of the holes, similar to how the guy in the how-to used the styrene plastic. It worked ok, and you couldn't really see the holes at all unless you were really close. I have since put my badges back on, tho. I actually like it better.
Yea def guna have to fill it with some bondo or some kind of filler, and then have it sanded down and resprayed
I should have had this done when I had the kit installed :(
That looks so clean, nice ride man
i dont think the emblems r glued on. the have sticks in them that go thrwugh the trunk. ive looked into doing this once. it seems that u can get som pliers and squeeze the notches on the sticks in, and pull the badge clean off? ass far as holes, u will have to use bondo to fill them, and if ur paint isnt bad, u will need to sand around the hole, about the same sizes as the badges, and repaint that area. thats about whats going to happen hands down.
