ECU Reprogramming
travisto
titanium 04' MSM
(pullup) After almost giving up on our s*** ECU's and someone making an aftermarket chip than doesn't cost 800 ******* dollars!(assholes) (cool) I finally found a guy here in Tulsa that used to work for Mazda, has all the codes, and the computer to reprogram my ECU. Now I'm asking my fellow MSP owners, if you could have 3 things done to your ECU, what would they be? (pullup)
I would give my ECU artificial intelligence, make it blue, and put guns on it.
u dont have 3 options, u have 2.
old map or new map.
3rd option is to throw your ECU in the trash.
lol. that is like the 5th post i've read of yours that has you put guns on something.
drew
Aren't you the tenth person who has come here promising this? Not one has panned out yet.
Britt
what's the big deal with reprogramming anyway??
u'll never get anything other than the 2 maps that mazda (ford) designed for this car.
both suk.
mazda will never release the code to any other company.....say like hondata.....and these ECU's are coded so that noone is able to get into them.
many companies tried, big companies.
especially the RX-8 ECU.....which although runs a better program, is also protected like ours.
which is also the reason that noone has ever been able to succesfully turbo the Renesis.
if you could get it to suck you off while you drive, you might have better luck with that endeavor instead.
Instead of offering no actual help to this poor fellow who is making an honest effort to help us out...
(1) better base maps (Similar to a unichip map)
(2) speed limiter removed
(3) 2 or 3 stage launch mode (If they can do it to a 1991 Eclipse ecu, it should be possible on ours...)
What do you mean by number 3? Like a setting for sport and economy driving? How would you switch between them?
u guys are not understanding.
U WILL NOT BRAKE THE CODE.
.....sorry, but that's the truth.
Its like a stutter box. You arm it by putting in the clutch, ebrake on and then release it, and then you are in "launch mode"
Basically you can floor the car and it will keep it at lets say 3500 rpm's regarless of how hard you depress the accelerator. When you release the clutch you have a "perfect launch" and on dsms it keeps your rpms down until you reach a certain speed (for fwd to reduce spinning) and then upon you puttin in the cltuch it kicks out of launch mode and allows you to go into WOT... Make your launches much easier and reliable...
But I agree the code would be allmost impossible to break...
It's not impossible. Nothing along these lines is impossible. The more probable is that no real reverser has even attempted. *NOTE* I said "reverser" someone who actually reverses code for a living.
I need a reprogrammed ECU for my ES. I have the MSP turbo setup and the old MSP ECU, need to get it flashed way too much hesitation, but this may also be a posibility. I also have my old ES ECU still.
