EBC install help.
boosted3
Got a Greddy P-spec B and am having trouble locating where to tap into fuel pressure regulator.
Any help would be appreciated.
We don't have an FPR. You can't use that feature. Our CDFP has a built-in valve that regulates flow (and thus pressure), but you can't tap into it nor would you want to, since it is HIGH pressure.
Thanks for the reply... okay, so ummm.. how do I hook this bad boy up then? I mean, just skipping that step seems a bit spooky to me. Is there an alternate way? or do you just skip it? That has to be plugged into the back of the profec, do I simply leave it open?
I actually did and couldn't find the answer.. Perhaps I'm not too good at using the search feature. I'll try again.
Thanks again for the help.
Yeah, those are the same results I got. None of them tell me where to connect the vacuum line in place of a fuel pressure regulator, though. :)
