your not seeing that kind of boost where it makes peak power Ill tell you that. The stock dv leaks for sure. I tested it. Starts leaking bad at 12psi.
I just put a forge on the car and picked up 10whp from off idle to 4k and then around 20whp from 4k to 6.5k. I just havent posted the graph. That was on stock boost levels. would be alot more with a boost controller.
He's right. You can test it yourself with a DIY leak tester. Forge was the first thing i added along with a CAI.
Haltech would you say that you had gains like this?
