Downpipe on,so is Check Engine light-s***!
twiztedjeckel said:
wow, isn't that special for you. now smuggle a bunch of those downpipes in your ass and start husslin across state lines to hand them out to people. you can charge them shipping and possibly make money on the deal. plus you'll learn the ever so cool trick of hiding things in your ass. i hear Yashooooooooa hides his banshee mimicing daughter in there when she's screaming her delightful little lungs off
now get movin!:D
(lol) (rofl) ....you just made my day man......ill see what I can do...lol
i am cofused about this.
isnt the peeice of exhaust righ after the resonator/cat peice just one peice of pipe all the way back to the muffler? So are you there fore still running with on cat? Or is it 2 peices? I am sorry it is late and i cant run outside and look
too tired
step 1: remove gauges
step 2: remove CE light in gauges
steo 3: reinstall gauges
step 4: enjoy your enviroment killing cat-less car with out
a CEL
ghetto fix but it works :D
ForceFed said:
ok i know i'm gonna get flamed on this one from someone but here it goes!
High-flow(supossed)cats are a joke!All cats must meet the the same EPA requirements regardless of whether they are high flow or stock.(period!)The only thing that makes a high flow(once again supossed)cat any different than a stock one is the size of the inlet and outlet.(2 inch vs. 3 inch for example)The inners of all cats look the same and have the same restrictive type honeycomb material that makes them function.Yes you may put a bigger high flow(supossed)cat on your ride but will it really flow any better?It probably will but not enough to justify the cost of them for performance reasons.The internals of the cat are what makes them restrictive.
Have you guys preaching about high flow cats ever wondered why the companies that produce these don't put up flow comparison charts?Well I know why!Because they don't produce enough of a difference to justify them.If you are going for performance(especially on a turbo car)you need a higher flowing exhaust .You may gain a small amount of overall exhaust flow by putting in a single high flow cat,but it will be gained primarily by eliminating one of the cats.I.E. less restriction.You may even gain a little more from upping the exhaust piping size and putting on a high flow but you will still be restricted by the cat,period.If you want the least amount of restriction then the absolute best way to go is no cats at all!Yes I understand the environmental issues you are referring to and yes a cat would solve the CEL issue but most of the guys on these boards with MSP's are looking for the best bang for the buck when it comes to making the MSP fly!The only drawback that these types of guys are going to run into is staring at the dreaded CEL light till we get the permanant fix together to trick the ECU.
This is not a rant and this is by no means directed at any one person,This is just the way I see things!
This is my .02 cents,feel free to chip in yours!;)
Matt:cool:
couple things i want to clear up here on your post.
high flow cats and OE cats do have basically the same internal catalyst components. i dont know if you have read any of my proir posts either in this thread ot others so i will clarify and restate.(BTW i know you said it wasnt directed to any one individual;) :p )
high flow cats as per the name is a little ignorant. the reason they are effective are two fold. because they are able to "clean up" the emmisions from your engine and they have a higher "FLOW CAPACITY" then your stock converter.
there is a difference when you say restriction, backpressure or flow capacity.
for example when you turbo charge your vehicle and are flowing a larger volume of air at the given rpm your exhaust has to have the same ability to capasitate the flow of exhaust gases. thru the years and sufistication of fuel injection, ignition and A/F metering devises (O2 sensor and closed loop operation occuring sooner in most systems) the need for a very "restrictive" catalyst isnt there like there was in the early 80's when they still had feedback carbs and throttle body injection. the cats today from the OE manufacturers are really not that restrictive to the point where they create backpressure, they are restrictive in their capacity to how much they can flow.
many people think that when they increase the size of the exhaust from the cat back they are getting more power. they think there was so much "backpressure" in the system that it will stiffle flow and create less power. this is wrong. the system can only ingest and expell so much. but the engine can produce whatever it was designed to pump out.when they see a hp gain they see it in the upper rpm range when the engine is at its peak efficiency and needs the additional capacity to flow what it was allready able to produce but couldnt because the "piping " was to small in diameter. there is also a difference in keeping velocity in the system and allowing too little flow and losing some needed torque, thru scavenging and tuned exhaust gas harmonics in the lower part of the rpm band.
those exhaust pulses low in rpm is what gives you the initial power your looking for but the hp needed to sustain power levels needs to have an exhaust system that can breathe well in the upper limits also. stock cats are ok but just not enogh when your looking to increase the amount of CFM thru the engine faster than N/A operation as with forced induction.
backpressure is a myth,restriction to flow is another. its flow capacity and exhaust pipe diameter that controls that.
i preach about cats only because it will save you headaches with the smog boys and unless you have an experienced tuner that can tune your car with a piggy or standalone you will never pass emmisions.
and we all want to stay legal right??
so the larger flow capacity cat WILL help for power gains.
but if you dont care about emmisions testing and the ecu funcion than go catless.
like i said in an earlier post, we can be here all day discussing this topic but i tried to put as much info as i can in "real world" terms to get my point across.
im sure there is some stuff i skipped so i can go into detail if someone would like to ask.:D
Well put perfworks, now my question is this. The PCM is expecting to see two O2's one before the first cat and after the first cat correct?
If this is so, then I am going to get someone to make me a 2.5 inch pipe that comes from the downpipe to the rear muffler section, eliminating the resonator but adding 1 High Flow cat. I do not want to hack my existing exhaust system so as I can replace it before I go to the dealership.
the ecu will use the stock O2 sensor under closed loop operation
only to monitor A/F ratio at or near the exhaust collector of all the cylinders.since your turbocharged the logical choice will be after the turbo for two reasons:1. that particular cast manifold gets way to hot under load and high rpms so it will crusify the sensor by melting it away if mounted in the manifold.2. because the turbine acts like its own "afterburner" (catalyst) by reducing the amount of unburned gases entering the exhaust before the converter thru increased manifold temps
the second O2 is where the problem lies because the sensor is not used for fuel dispertion. it is there to make sure the the cat (or ANY cat ) is doing its job by measuring the amout of oxygen in the exhaust in comparison to a set parameter in the eprom.. a particular voltage differencial between the two sensors needs to exist. it doesnt necessarily have to show a "clean bill" but just that the cat is "trying " to clean things up
so the setup you are going with is fine . it is what i have recommended many times. just make sure the O2 is threaded after the high flow cat (or after the last cat in your system)
hope this helps:D
perfworks, I by no means argue with you about what you said in any posts that you have submitted.I only state my point of view on cats and your point is almost right on with mine except for the fact that you like to use the high flow and i like to use nothing at all.You are by no means throwing out any false info nor am i.I beleive that we both know a lot about cars and tuning but we just tend to differ a little on the way we do things and there is nothing wrong with that!This doesn't mean either of us are doing it wrong but rather that we take different approaches.I respect what you say and you seem to do the same with my posts and I appreciate this.What I have just said has not been a common occurance on the board as of late because everyone thinks they are always right and only see things one way!This is not always the case and a informed "DISCUSSION" is what most people need to be in as we are where we both show the pros and cons of our views.I appreciate the fact that we can discuss things and not get into a flamewar as this does no one in the community any good at all!I respect you for having one of these with me on this post and that makes me respect your "educated" opinion even more!
Thank you ,Matt:D
Thank you ,Matt:D
thats what we all are striving for i hope.:)
you da s*** too man:p
no its cool i dont take anything personal at all. we are here to discuss s*** like it was meant to be. some cant do it very well though they get a little upset but its cool, we at least know that sometimes we will differ and that makes me stay on my toes for new info.
good job man and keep up the good posts:D
My opinion now. Well I am used to Honda's and this is what I picked up. When your o2 sensor senses a fault it will make the PCM retard the timing and cut a/f mix down so as to help reduce emissions. I might be wrong but isnt removing the cats and setting o2 codes on are MSP limiting their power due to the PCM...?
This is for the mazda ecu:
The primary O2 sensor only monitors A/F ratios. It sends a voltage signal back to the PCM and the module verify's closed loop operation and then looks up preprogrammed values. Adjusts the injector pulse rate accordingly.It will not adjust timing at all. The job of the O2 sensor has nothing to do with the ignition process. The knock sensor is the primary circuit that will send a voltage signal to the PCM warning it of detonation. Only the knock sensor voltage to the PCM will retard timing . Nothing else.
Now the primary O2 sensor will not set a code. The PCM will if the voltage input from the the sensor(s) are "out of set parameters" in a given load and throttle situaition. Along with that it will only take O2 sensor voltage into concideration when in closed loop(where all the factory sensors are acting together to provide an input to the ecu for proper performance )
Removing the cats will not necessarilly harm power output, the CEL's might. If the PCM shows a serious emmisions fault after two consecutive drivecycles then it can harm performance by going into "limp home " mode. Where the car will barely run sluggishly untill the diagnostics check and/or reset of the PCM
okay, so the guys gutting their cats are in the end slowing their cars down then? I am not bashing anyone I am trying to figure out what I want to do, without affecting driveabiliy.
they are not slowing their cars down.
the PCM is setting the warning light. IT CAN and MAY set a drivability or emmision code and then it will harm performance.
to just not have that happen i recomend running at least one cat and that will be just as cheap as any ecu trick for the O2 voltage signal simulator and is guaranteed to work
summit racing sells catco universals. my 3" was only $45
some dont mind the CEL and chose to get rid of the light. for the performance increase up top without cats its just not a good opton in my opinion. if you dyno the car with a high flow and then with the eliminator pipe you would be surprised at the results from the comparison
HMMMM?????...You might be surprised by the comparison and then .........
You might not
It will take a dyno to prove these numbers to me:D
BTW,thanks for understanding my point of view perfworks!
