M MS3 Ventura Member Dec 1, 2008 #1 Anyone know how to disconnect the steering shaft from the steering gear and linkage? Thanks
M Mike240SX Member : 1994 Mazda NA Miata M-Edition Dec 1, 2008 #3 Same as any other car, I can't imagine why it wouldn't be. Raise car. Get under car. Remove plastic undertray. Locate where steering shaft enters steering rack. Locate bolts. Use appropriately sized wrench to remove bolts.
M MS3 Ventura Member Dec 1, 2008 #4 Thanks Mike. I'm disconnecting it so that when I lower my sub-frame to install my front anti-sway bar it won't put too much stress on it.
