Difference between MP3 & P5?
I know you can fit the msp springs on the p5 so I would imagine that that struts would fit as well. However isn't the rear of the p5 a lot heavier then the msp theirfor causing the ass end to sag alittle with msp springs?
Bump for an answer....
Wanting to know if the struts from a msp or mp3 fit on the p5...
About the springs your logic make plenty of sense...
I figure'd I might as well throw the weight factor into it as the rear struts on the p5 maybe different due to the weight of it, but you never know.
Yes, all 3rd gen struts are interchangeable. This has been covered again and again, and you probably could have found your answer very easily with a search.
Springs are also interchangeable, but the P5's run a higher spring rate in the back because of their heavy booty.
Now you know...
Now you know...
Found the answer yes. Easily? Not to sure. Try searching strut, strurts and tell me how many pages pop up. Besides the questions in the right thread.
