DaveB Instructional Video: I lost mine :(
I lost my DaveB Instructional Video and a major pothole shook off one of my guage rings.
Does anyone have a site I can download the vid from? I don't want to screw up my dash.
video is huge, but you could load the how-to pdf from my site 8-B
(can't link it from here)
as i said, a direct link doesn't work, the downloads are protected from direct linking from the outside...
you can click the picture in my sig,then you will get to my page... it's in the faq section under interior/ "Deinstall gauge cluster"
tilt steeringwheel down fully
unscrew 2 phillips screws under the top of the dash (on the black plastic bezel)
pop the rest off slowly (each side has a clip)
unscrew 2 scrws on bottom of gauge cluster
unscrew 1 screw on top of gauge cluster (metal bracket)
pull forward on metal bracket
unscrew screw on metal bracket to cluster (to remove bracket)
Unclip electronic harnesses on top of cluster , i think there 2 or 3
pull cluster up and out (with bracket removed)
useing a screwdriver loosen the plastic cover from the cluster 1 at a time
careful not to break any of the clips. i just loosen one, pull it out a bit, move
to the next.
then replace rings (dont touch needles) and reverse.
voila.
hope this helps.
