dashlights out
bumpin-MX6
Mazda MX-6
so since it was only like 5 degrees outside i decided to go somewhere and get the stereo put in because factory from a 95 just wasnt cutting it. the shop did a terrrible job and didnt listen to a word i said. went in with perfect amount of wire and everything planned and measured on how i want it. they left wire strippings everywhere and even tools under my hood and under my backseat. but when i got my car back i noticed my dashlights wont work. i was wondering if a wire touched with another and blew a fuse some where. my friend had a 91 protege and he said the tail lights are on the same fuse as the dash lights but my tails work. and usually the dash is on the same fuse as the radio but that works too. any suggestions would be apreciated.
oh and i forgot to mention i drive a 95 mx6
I'm trying to remember from my MX-6, I had a 93 but I think the dash is on a seperate fuse. Check the kick panel box with a tester and see if you can find the right one... or you could check out www.mx6.com, you should be able to get some more info on there. The MX-6 is closer in relation to the 626 than to the protege so most people on here won't really be able to help you out.
