DashHawk Replacement?
cghms3
2009 mazda mazdaspeed 3 metro grey
Hi, got my Autotech fuel pump internals installed, and I can feel the difference in drivability - much more smooth, and more importantly, it will have higher fuel pressure and not fail. Anyway, I was told to get the MSD DashHawk to monitor engine parameters, however, I found out that it is discontinued. What should I get (i am learning about what parameters to monitor, and the DashHawk seemed easy to use/learn). What is the next best unit, and does it plug into the OBD port like the DashHawk? Thanks!
Aero Force interceptor scan gauge is pretty awesome, you can even run a dual gauge setup block8head makes an awesome single or dual gauge pod. if i didnt have a dashhawk id get one or two :)
Hey thanks for the info, zoomzoomMSP - I'll do some research on both them, and see which is the best fit for me. Would buying a used DashHawk (if there are any for sale) be just as good as the Aero Force interceptor or the block8head, or are they much better then the DashHawk?
I had the interceptor gauge and I now have the DashHawk. I prefer the DashHawk. There is one on sale on mazda 3 forums right now for $150 shipped.
I Prefer the Dashhawk as well, but MSD no longer supports the Dashhawk anymore so if you have issues your screwed. you also really need a computer wiith windows XP on it for it to function/update on your computer without all the hassles of the newer versions....vista and win 7.
Good point about not having factory support for the DashHawk. Looks like new is the way to go...
Thanks rsvinylgraphics, but finances are tight for awhile. I have to wait until things get a little better - Thanks again for the offer though!
