Daily-Driven big turbo MSP Build up
brian's just messin around...this weekend will be the weekend for timing implementation. Give the guy with the MSP my info, I'd be more than happy to help him get that thing sorted out, it'd be great to have multiple cars running MS.
Just so everyone knows, brian's MSP with a unichip (high boost and agressive timing) outran my car at 15psi by a good bit. It was fun, but it certainly goes to show what a good tune does. Just wait till i can get some timing going, brian! then it's onnnn! j/k... power grudges are so dumb...anyways, timing this weekend, and new H20 pump(took a giant s***), so we'll see what's up.
-Mateo
ND4MSP said:
Yeller, your car sounds clean as hell. Can some of this be attributed to the 50 series muffler. Not a lot of import guys run the flows, but I've seen a few vids with some well sorted hondas and they sounded just right also. No rice to be heard
yeah, I'm almost certain that's the 50 series. It sounds a little too ricey when you're off boost for my tastes, but that is greatly offset by the sound it makes when on boost. The sound quality in the video is horrible, it sounds AMAZING in person. just simply amazing. it gives me the shutters to think about it. You know you're a happy man when you shudder when you think about driving your own damn car...yeeeehaw!
-Mateo
I'm happy I am running my GT28RS.
I will be running with you guys soon,my MAF,TPS,and pre 02 took a s***.
im leaning towards putting in a 16g for now.. and an 18g later.
or a 14b with the 16g compressor housing.. that'd cost me all of $80 and flow 10% less than the 16g..
either way, need big turbo.
cheap is good.
you ever consider useing a T4?you can get then for pretty cheap,or a holeset?
Nice work brother. I will be following your footsteps soon. I think that I'll be doing the MS build over the winter in addition to the block stuff.
R
nice. Might i recommend buying an assembled box, and doing the rest of the wiring yourself? It's enough of a hastle to get that working; messing with the MS and the wiring at the same time would be murder. Awesome that you're goin MS though! woohoo!
-Mateo
And thanks for the compliments, gents.
-Mateo
those things are hella easy to build though,and it's half the fun.
hella easy to build, yes, hella easy to get everything working correctly? only if you really konw what you're doing. I def wanna keep in touch with you if you do go that route!
