CX-9 Technical Service Bulletins Listing
ab040501
2008 CX-9 GT
Should we put a list or attachments of all the TSB for CX-9 here. At least it is easier for person like me to present to dealership about my problem. No question ask!!! It's like slapping them on the face when they refuse to do so.
Here's the link:
http://www.finishlineperformance.com/store/pages.php?pageid=15
Can I use this technical service bulletins if my car is affected as describe. Can a mazda dealership say no or refuse to do the work?
Can someone please explain if these service bulletins same as recall? I'm interested to know how can I use these information to my advantage.
Legally can I use these service bulletin, to make dealership fix issue that they are reluctant to work on due to the fact that they may not get paid by warranty company? Is this applicable to Canada or US since the person who post it seems like from Canada.
A TSB is not a recall.
TSBs tell mechanics at dealerships of Mazda (or whoever allowed to access the data base) that certain issues
exist in certain models/years (VIN range), and the proper fixes for them (and parts No to order).
TSBs do not guarantee that you can have them fixed free. For that, it still depends on your warranty coverage.
If an issue is safety-related, it will be elevated to a recall. In that case, fixing them are free of charge.
Does anyone have an updated list of TSBs for the 2011 CX-9?
I can get you the full version on any tsb you are looking for specifically, as there are a ton of them. The most recent tsb I am aware of is for blown struts (including 2011), and then before that is the tsb for bad coils (tsb is not for 2011 models which indicates coils have been re-designed for more recent year cx-9's)
A bit googling can find the list.
helbigtw is offering the detail content of a TSB, which is hard to find.
I am sure I will come to you when I need one.
Interesting because I called Mazda Canada, gave them my VIN number and they told me there are no TSBs for that vehicle. Would love to go over the list you have if you have time to post it.
Thanks!
This is true, and when you are out of warranty it might take a while to get a compromise on Mazda paying anything. But armed with a TSB gives you the best leverage, since it is an admission that something wasn't quite right to begin with. We were out of warranty when our tailgate started rusting, but there is a TSB somewhere that addresses this, so all we had to pay was $80 and Mazda covered the rest (which was several hundred dollars).
2011 AWD:
0200411 07/11/2011 Suspension - Strut/Shock Replacement Guidelines
0200311 06/23/2011 Tire Monitor System - Service Precaution
0300311 06/17/2011 Drivetrain - Transfer Case R/H Output Seal Leaks
0901511 06/13/2011 Instruments - Ambient Temperature Display Inaccurate
0700511 05/31/2011 A/C - 'Inoperative A/C' Troubleshooting Tips
0400611 04/15/2011 Brake - Front Brakes Squeak On Brake Application
0400411 04/13/2011 Brakes - Rear Brake Groan When Applying Brakes
0800311 03/25/2011 Restraints - Passenger Air Bag Deactivation Lamp ON
0900911 03/01/2011 Body - L/H Door Mirror Vibration
0900811 02/23/2011 Cell Phone - Bluetooth(R) Troubleshooting Information
0900711 02/23/2011 Body - Sunroof Is Inoperative
0400211 02/15/2011 ABS/TCS - DCS Lamp ON/DTC C1963 Stored
0900511 02/07/2011 Lighting - Excessive Water/Condensation In Headlamps
0100311 01/12/2011 Electrical - Battery Maintenance
0905710 12/23/2010 Lighting - Condensation In Front/Rear Lamps
0905410 12/13/2010 Body - Paint Damage Repair Guide
0105410 12/13/2010 Electrical - Battery Testing Procedures
0400610 10/22/2010 Brakes - Clunk/Bang On Initial Forward Take-Off
0501210 09/30/2010 A/T - Cooler/Line Flushing Procedure
0904110 08/30/2010 Keyless Entry - Transmitter Battery Replacement Cautions
MTIP-08-03-1 03/01/2008 A/C - Poor Blower Motor Performance
Thanks!
They probably thought you meant "recall".
Some TSBs have no VIN range attached to it unless it is associated with a bad batch of parts.
I am sure there are at least ONE TSB that applies to you need to keep an eye on.
2008 List: (lemme know if any full version is needed)
Number Date Title
0102611 07/13/2011 Ignition/Engine Controls - MIL ON/DTCs P0351-P0356
0901611 06/30/2011 Body - Power Liftgate Malfunction
0500411 06/21/2011 A/T - Diagnostic Procedures
0700311 04/13/2011 A/C - Blower Motor Stays ON With Key Turned OFF
0400111 02/07/2011 Brakes - Pedal/Steering Wheel Vibration Above 45 MPH
0105210 11/05/2010 Fuel System - MIL ON/DTC P2135 Set
0103510 06/02/2010 Engine Controls - Cold Engine Ping/Spark Knock
0400310 05/27/2010 ABS/TCS - DSC Activation On Low Speed Turns
0103210 05/27/2010 Engine Controls - O2 Sensor Removal Precautions
0103110 05/25/2010 Instruments - Odometer Write Deletion On M-MDS
0102910 05/17/2010 Engine Controls/Electrical - Engine Harness Replacement
0200510 03/26/2010 Steering - Steering Wheel Is Off Center
0200410 03/24/2010 Tire Monitor System - Service Precautions
0300210 03/08/2010 Drivetrain - Drive Axle Clunking Noises
0901110 02/17/2010 Interior - Avoiding Driver Floor Mat/Pedal Interference
0101310 02/15/2010 Electrical - Battery Testing Procedure Requirements
0900910 02/12/2010 Wipers/Washers - Wiper Blade Insert Replacement
0900610 02/08/2010 Cell Phone - Bluetooth(R) Hands Free Pairing Inoperative
0101010 02/02/2010 Battery - Testing Information
0900210 01/07/2010 Body - Windshield Flaw/Scratch/Crack Information
0900310 01/07/2010 Keyless Entry - Remote Transmitter Is Inoperative
0908109 12/21/2009 Navigation System - Display Standard For Failed Pixels
0907609 11/25/2009 Interior - Seat Trim Replacement Procedure
0907709 11/25/2009 Electrical - Window Fuse Blows When All Windows Operated
0907409 11/13/2009 Navigation System - Service Information
0906909 11/12/2009 Interior - Seat Back Squeaking Noises
0906309 10/27/2009 Interior - Front Seat Head Rest Rattling Noises
0906409 10/27/2009 Interior - Front Seat Back Squeaking Noises
0906509 10/27/2009 Interior - Squeaking Noise From Under The Driver's Seat
0905909 10/23/2009 Interior - Driver's Seat Chatters/Seat Lift Inoperative
0906009 10/23/2009 Interior - Front Seat Clunk Noise While Braking
0906109 10/23/2009 Interior - Seats Noisy/Shake Back And Forth When Braking
0906209 10/23/2009 Interior - Leather Seat Squeaking Noises
0905609 10/07/2009 Body - Wind Noise From Top Of B-Pillar
0905209 09/18/2009 Instruments - Driver's Side Mirror Vibration
0501509 09/04/2009 A/T - Fluid Leaks From Servo Cover
0904709 08/17/2009 Lighting - Headlamp Protector Comes Off
0103309 07/24/2009 Interior - Accelerator/Brake Pedal Vibration
0903409 07/10/2009 Body - Engine Compartment Shroud Appearance
0903509 07/10/2009 Lighting - Plastic Headlamp Lens Maintenance Cautions
0903209 07/07/2009 Interior - Poor Dash Surface Appearance
0700209 06/24/2009 A/C - Musty/Mildew Odors From vents
0903009 06/24/2009 Audio System - Speaker Noise When Using Auxiliary Device
0200609 06/22/2009 Suspension - Front End Squeak/Chirp Noises
0400609 06/02/2009 Brakes - Noise/Judder/Dragging
0902509 05/29/2009 Electrical - Chime Stays ON With Key OFF
0800309 05/15/2009 Interior/Restraints - Seat Belt Buckle Rattles/Squeaks
0902309 04/16/2009 Body - Rear Quarter Glass Replacement Precaution
0902209 04/06/2009 Body - Service Bumper Specification Change
0902009 04/01/2009 Lighting - Insect Inside Rear Combination Lamp
0901509 03/18/2009 Body - Rust Around Liftgate Moulding
0800209 03/06/2009 Restraints - Air Bag Lamp ON/DTC B1342/B2477/C1946
5309B 03/01/2009 Recall - Power Seat Wire Harness Damage
NHTSA09V066000 02/20/2009 Recall 09V066000: Power Seat Harness Inspection
MTIP-09-01-9 01/01/2009 Interior - Console Damage Prevention During Removal
MTIP-09-01-8 01/01/2009 Audio System - iPod(R) Adapter Application Table
MTIP-09-01-5 01/01/2009 Fuel System - Fuel Ethanol Content Testing
MTIP-09-01-4 01/01/2009 Instruments - Info. Display Full Afetr Remote Start
MTIP-09-01-2 01/01/2009 Engine/Brakes - Rattle Noise Under Load At 1700-2000 RPM
MTIP-09-01-1 01/01/2009 Body - Door Mirror Vibration
0300608 12/12/2008 Drivetrain - Excessive Driveshaft Vibration/Noise
MTIP-08-12-6 12/01/2008 Navigation System - Beep Sound From Dash While Driving
MTIP-08-12-5 12/01/2008 Instruments - Unique Warning Lamps
MTIP-08-12-4 12/01/2008 Engine - Oil Level Inspection Precautions
MTIP-08-12-3 12/01/2008 Audio System - Satellite Radio Serial Number Retrieval
0800408 11/21/2008 Restraints - Air Bag Lamp ON/DTC B2290 Set
0903308 10/03/2008 Interior - Paint Peeling From Arm Rest Garnish
0104608 10/01/2008 Remote Start System - Blows A/C and Ign. Fuses
0902708 09/08/2008 Instruments - Clock Loses 21-35 Seconds Per Week
0104408 09/05/2008 Engine - Oil Level Service Caution
MTIP-08-09-4 09/01/2008 A/T, Drivetrain - Click Noise When Shifting Into Reverse
0902508 08/29/2008 Instruments - Configuring Odometer Data
092408 08/20/2008 Body - Liftgate Handle Hard To Grip
0103408 07/08/2008 Emissions - DTC P0442, P0455, and P0456 Diagnostic Info.
0902008 07/08/2008 Navigation Radio - Audio CD Text Does Not Display
MTIP-08-07-6 07/01/2008 Wipers/Washers - Rain Sensor Initialization
MTIP-08-07-4 07/01/2008 Entertainment System - DVD Screen Display Inverted
0103008 06/23/2008 Computers/Controls - Module Reprogramming Precautions
0901708 06/17/2008 Audio System - Sirius Satellite Radio(R) Activation
0500808 05/23/2008 A/T Controls - Power Reduction When Climbing a Hill
MTIP-08-07-5 05/01/2008 Mirrors - Door Mirror Glass Is Loose
MTIP-08-05-5 05/01/2008 Tire Monitor System - Can't Turn OFF/On Reprogram
MTIP-08-05-3 05/01/2008 A/T - Shifter Won't Move Out Of PARK
0300408 04/11/2008 Drivetrain - Front Axle Knocking Noises in Extreme Cold
MTIP-08-03-2 03/01/2008 Cell Phone - Bluetooth(R) Troubleshooting
0900308 01/16/2008 Navigation System - Displays Incorrect Map or No Map
MTIP-08-01-4 01/01/2008 ABS/TCS - Warning Lamp Stays ON Until Igntion Cycle
MTIP-08-01-3 01/01/2008 Body - Rear Fender Moulding Gap
MTIP-08-01-2 01/01/2008 Electrical - Cruise Control Cancels Using Turn Signals
MTIP-07-12-4 12/01/2007 Wheels/Tires - Tire Pessure/Rotation Information
MTIP-07-12-3 12/01/2007 Mirrors - Interior Mirror Removal
MTIP-07-12-2 12/01/2007 Vehicle - Lifting Precautions
MTIP-07-12-6 12/01/2007 Fuel System - Ethanol Fuel Usage
0400507 11/07/2007 Brakes - Rear Brake Squeaking Noise
0903607 11/07/2007 Lighting - Front Map/Dome Light Switch Falls OFF
0200607 10/03/2007 Wheels - Stain Prevention Information
0903407 10/03/2007 Entertainment System - Rear Seat Headphones Broken
0103307 08/29/2007 Cooling System - Pre-Mixed Long-Life FL22 Coolant Info.
0902507 08/29/2007 Interior - 2nd Row Seat Will Not Slide
MTIP-07-10-4 07/01/2007 Drivetrain - Transfer Unit Replacement Tip
MTIP-07-10-2 07/01/2007 Collision Avoidance - Blind Spot Monitoring System Intro
MTIP-07-07-2 07/01/2007 Entertainment System - DVD Screen Protector Precautions
DAMNNNNNNNNNNNNNNNNNNNNNNNNNNNN !!! The 2008 looks like it needs to be completely recalled and re-done - how in the hell can any car have that many TSB's and not be recalled?
How does this TSB list for the CX9 Yr 2008 compare to other 2008's of like SUV's? Ie, Acura MDX SUV, etc?
BTW, I have a 2009 CX9 GT, how does the list of TSB's look for that model?
I currently have 46.5K and this is what I have had done to date: replace the relay blower switch, replaced on of the struts, replaced all of the interior silver trim [ the second ones have worn off too ???] That is about it, so I guess I am lucky, yes?
Best Regards,
tstex
2009 is about the same, will post another time. Keep in mind "M-TIP" is mechanic's tip basically a "hey I found this trick for this rattle" or so on, m-tip's are not tsb's.
Basically a TSB is when a number of customers come in with the same/common complaint, it is mazda saying "mr. technician, here is how to fix this common problem....and if a customer compains about xyz, this is probably what this is" And often the TSB will refer the technican to a certain area in the service manual.
Basically it keeps the technicians from trying to guess what the problem is and it points them in the right direction.
thx for both the clarification and future info - rgds, tstex
You might to surprised but the list of TSBs for CX9 is not specially long.
My wife's '05 Prius already had four recalls on it. I can't imagine how long the
TSBs would be. My CX9 however has only 1 recall for the power-seat.
Number Date Title
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Can you post the list for the 2010's please?
2010
Number Date Title
0400711 10/17/2011 Brakes - Judder/Dragging Diagnostic Information
0103311 10/05/2011 Fuel System - Intermittent Engine Stalling
0500811 09/21/2011 A/T - Cooler Line Flushing Procedures
0300411 09/21/2011 Drivetrain - Rear Differential Oil Seal(s) Leaking
0104510 08/24/2010 Campaign MSP31 - Throttle Body Replacement
0903810 08/24/2010 Campaign MSP30 - Bluetooth(R) System Inoperative
0901710 03/30/2010 Locks - Ignition Lock Cylinder Replacement Part Info.
5810B 03/01/2010 Recall - Potential Seat Heater Fires
0901310 02/24/2010 Electrical - Accessory Charger Sticks In Aux. Power Port
NHTSA10V051000 02/19/2010 Recall 10V051000: Seat Heater Modification
0900510 01/19/2010 Interior/A/C - Seat Heater Won't Turn Off
0903609 07/17/2009 Paint - Paint Stain Removal Information
0903709 07/17/2009 Paint - Aqua-Tech(R) Paint System
