CX-9 Technical Service Bulletins Listing
2012
0400711 10/17/2011 Brakes - Judder/Dragging Diagnostic Information
0500811 09/21/2011 A/T - Cooler Line Flushing Procedures
0200411 07/11/2011 Suspension - Strut/Shock Replacement Guidelines
2007
0300411 09/21/2011 Drivetrain - Rear Differential Oil Seal(s) Leaking
0102611 07/13/2011 Ignition/Engine Controls - MIL ON/DTCs P0351-P0356
0901611 06/30/2011 Body - Power Liftgate Malfunction
0200311 06/23/2011 Tire Monitor System - Service Precaution
0500411 06/21/2011 A/T - Diagnostic Procedures
0901511 06/13/2011 Instruments - Ambient Temperature Display Inaccurate
0400611 04/15/2011 Brake - Front Brakes Squeak On Brake Application
0700311 04/13/2011 A/C - Blower Motor Stays ON With Key Turned OFF
0400411 04/13/2011 Brakes - Rear Brake Groan When Applying Brakes
0800311 03/25/2011 Restraints - Passenger Air Bag Deactivation Lamp ON
0900811 02/23/2011 Cell Phone - Bluetooth(R) Troubleshooting Information
0900711 02/23/2011 Body - Sunroof Is Inoperative
0900511 02/07/2011 Lighting - Excessive Water/Condensation In Headlamps
0400111 02/07/2011 Brakes - Pedal/Steering Wheel Vibration Above 45 MPH
0100311 01/12/2011 Electrical - Battery Maintenance
0905710 12/23/2010 Lighting - Condensation In Front/Rear Lamps
0905410 12/13/2010 Body - Paint Damage Repair Guide
0105410 12/13/2010 Electrical - Battery Testing Procedures
0105210 11/05/2010 Fuel System - MIL ON/DTC P2135 Set
0400610 10/22/2010 Brakes - Clunk/Bang On Initial Forward Take-Off
0904110 08/30/2010 Keyless Entry - Transmitter Battery Replacement Cautions
0103210 05/27/2010 Engine Controls - O2 Sensor Removal Precautions
0103110 05/25/2010 Instruments - Odometer Write Deletion On M-MDS
0102910 05/17/2010 Engine Controls/Electrical - Engine Harness Replacement
0200510 03/26/2010 Steering - Steering Wheel Is Off Center
0200410 03/24/2010 Tire Monitor System - Service Precautions
0300210 03/08/2010 Drivetrain - Drive Axle Clunking Noises
0901110 02/17/2010 Interior - Avoiding Driver Floor Mat/Pedal Interference
0101310 02/15/2010 Electrical - Battery Testing Procedure Requirements
0900910 02/12/2010 Wipers/Washers - Wiper Blade Insert Replacement
0900610 02/08/2010 Cell Phone - Bluetooth(R) Hands Free Pairing Inoperative
0101010 02/02/2010 Battery - Testing Information
0900210 01/07/2010 Body - Windshield Flaw/Scratch/Crack Information
0900310 01/07/2010 Keyless Entry - Remote Transmitter Is Inoperative
0908109 12/21/2009 Navigation System - Display Standard For Failed Pixels
0907609 11/25/2009 Interior - Seat Trim Replacement Procedure
0907709 11/25/2009 Electrical - Window Fuse Blows When All Windows Operated
0906909 11/12/2009 Interior - Seat Back Squeaking Noises
0906309 10/27/2009 Interior - Front Seat Head Rest Rattling Noises
0906409 10/27/2009 Interior - Front Seat Back Squeaking Noises
0906509 10/27/2009 Interior - Squeaking Noise From Under The Driver's Seat
0905909 10/23/2009 Interior - Driver's Seat Chatters/Seat Lift Inoperative
0906009 10/23/2009 Interior - Front Seat Clunk Noise While Braking
0906109 10/23/2009 Interior - Seats Noisy/Shake Back And Forth When Braking
0906209 10/23/2009 Interior - Leather Seat Squeaking Noises
0905609 10/07/2009 Body - Wind Noise From Top Of B-Pillar
0905209 09/18/2009 Instruments - Driver's Side Mirror Vibration
0501509 09/04/2009 A/T - Fluid Leaks From Servo Cover
0904709 08/17/2009 Lighting - Headlamp Protector Comes Off
0103309 07/24/2009 Interior - Accelerator/Brake Pedal Vibration
0903409 07/10/2009 Body - Engine Compartment Shroud Appearance
0903509 07/10/2009 Lighting - Plastic Headlamp Lens Maintenance Cautions
0903209 07/07/2009 Interior - Poor Dash Surface Appearance
0700209 06/24/2009 A/C - Musty/Mildew Odors From vents
0903009 06/24/2009 Audio System - Speaker Noise When Using Auxiliary Device
0200609 06/22/2009 Suspension - Front End Squeak/Chirp Noises
0902509 05/29/2009 Electrical - Chime Stays ON With Key OFF
0800309 05/15/2009 Interior/Restraints - Seat Belt Buckle Rattles/Squeaks
0902309 04/16/2009 Body - Rear Quarter Glass Replacement Precaution
0902209 04/06/2009 Body - Service Bumper Specification Change
0902009 04/01/2009 Lighting - Insect Inside Rear Combination Lamp
0901509 03/18/2009 Body - Rust Around Liftgate Moulding
0800209 03/06/2009 Restraints - Air Bag Lamp ON/DTC B1342/B2477/C1946
5309B 03/01/2009 Recall - Power Seat Wire Harness Damage
NHTSA09V066000 02/20/2009 Recall 09V066000: Power Seat Harness Inspection
MTIP-09-01-9 01/01/2009 Interior - Console Damage Prevention During Removal
MTIP-09-01-8 01/01/2009 Audio System - iPod(R) Adapter Application Table
MTIP-09-01-5 01/01/2009 Fuel System - Fuel Ethanol Content Testing
MTIP-09-01-4 01/01/2009 Instruments - Info. Display Full Afetr Remote Start
MTIP-09-01-2 01/01/2009 Engine/Brakes - Rattle Noise Under Load At 1700-2000 RPM
MTIP-09-01-1 01/01/2009 Body - Door Mirror Vibration
0300608 12/12/2008 Drivetrain - Excessive Driveshaft Vibration/Noise
MTIP-08-12-6 12/01/2008 Navigation System - Beep Sound From Dash While Driving
MTIP-08-12-5 12/01/2008 Instruments - Unique Warning Lamps
MTIP-08-12-4 12/01/2008 Engine - Oil Level Inspection Precautions
MTIP-08-12-3 12/01/2008 Audio System - Satellite Radio Serial Number Retrieval
0800408 11/21/2008 Restraints - Air Bag Lamp ON/DTC B2290 Set
0104608 10/01/2008 Remote Start System - Blows A/C and Ign. Fuses
0902708 09/08/2008 Instruments - Clock Loses 21-35 Seconds Per Week
0104408 09/05/2008 Engine - Oil Level Service Caution
MTIP-08-09-4 09/01/2008 A/T, Drivetrain - Click Noise When Shifting Into Reverse
0902508 08/29/2008 Instruments - Configuring Odometer Data
092408 08/20/2008 Body - Liftgate Handle Hard To Grip
0103408 07/08/2008 Emissions - DTC P0442, P0455, and P0456 Diagnostic Info.
0902008 07/08/2008 Navigation Radio - Audio CD Text Does Not Display
MTIP-08-07-6 07/01/2008 Wipers/Washers - Rain Sensor Initialization
MTIP-08-07-4 07/01/2008 Entertainment System - DVD Screen Display Inverted
0103008 06/23/2008 Computers/Controls - Module Reprogramming Precautions
0901708 06/17/2008 Audio System - Sirius Satellite Radio(R) Activation
0300508 05/23/2008 4WD System - 4WD/DSC Lamp Flashes/Front Wheel Spin
0500808 05/23/2008 A/T Controls - Power Reduction When Climbing a Hill
MTIP-08-07-5 05/01/2008 Mirrors - Door Mirror Glass Is Loose
MTIP-08-05-5 05/01/2008 Tire Monitor System - Can't Turn OFF/On Reprogram
MTIP-08-05-3 05/01/2008 A/T - Shifter Won't Move Out Of PARK
0300408 04/11/2008 Drivetrain - Front Axle Knocking Noises in Extreme Cold
MTIP-08-03-2 03/01/2008 Cell Phone - Bluetooth(R) Troubleshooting
MTIP-08-03-1 03/01/2008 A/C - Poor Blower Motor Performance
0900808 02/25/2008 Body - Wind Noise/Whistle From Outer Mirrors
0300208 02/01/2008 Drivetrain - Rear Wheel Bearing Humming Noise
0900308 01/16/2008 Navigation System - Displays Incorrect Map or No Map
0800108 01/04/2008 Restraints - Seat Belt Retainers Broken
MTIP-08-01-4 01/01/2008 ABS/TCS - Warning Lamp Stays ON Until Igntion Cycle
MTIP-08-01-3 01/01/2008 Body - Rear Fender Moulding Gap
MTIP-08-01-2 01/01/2008 Electrical - Cruise Control Cancels Using Turn Signals
MTIP-07-12-4 12/01/2007 Wheels/Tires - Tire Pessure/Rotation Information
MTIP-07-12-3 12/01/2007 Mirrors - Interior Mirror Removal
MTIP-07-12-2 12/01/2007 Vehicle - Lifting Precautions
MTIP-07-12-6 12/01/2007 Fuel System - Ethanol Fuel Usage
0400507 11/07/2007 Brakes - Rear Brake Squeaking Noise
0903607 11/07/2007 Lighting - Front Map/Dome Light Switch Falls OFF
0200607 10/03/2007 Wheels - Stain Prevention Information
0903307 10/03/2007 Interior - Rattle From Second Row Seat Armrest
0903407 10/03/2007 Entertainment System - Rear Seat Headphones Broken
0103307 08/29/2007 Cooling System - Pre-Mixed Long-Life FL22 Coolant Info.
0103607 08/29/2007 Campaign MSP15 - Coolant Sub-Tank Replacement
0902507 08/29/2007 Interior - 2nd Row Seat Will Not Slide
MTIP-07-10-4 07/01/2007 Drivetrain - Transfer Unit Replacement Tip
MTIP-07-07-7 07/01/2007 Electrical - Lightning Strike Information
MTIP-07-07-6 07/01/2007 Wheels - Aluminum Wheel Cleaning Precautions
MTIP-07-07-5 07/01/2007 Wipers/Washers - Auto Wiper Operation
MTIP-07-07-4 07/01/2007 Drivetrain - AWD Transfer Case Fluid Fill/Checking Info.
MTIP-07-07-3 07/01/2007 Body - No Engine Under-Cover Installed On Vehicle
MTIP-07-07-2 07/01/2007 Entertainment System - DVD Screen Protector Precautions
SSP73 07/01/2007 Campaign - Front Door Hinge Check replacement
0200307 06/23/2007 Steering/Suspension - Vehicle Pull or Drift
0901607 06/23/2007 Interior - Grease Seeping From Audio Panel
0901507 06/23/2007 Instruments - Check Fuel Cap Warning Lamp Description
MTIP-07-05-1 05/01/2007 Audio System - Grease Appears On Audio Panel
0900507 03/19/2007 Navigation System - Displays No or Incorrect Map
0900307 03/19/2007 Body - Liftgate Glass Replacement Caution
2008 Mazda CX-9 AWD
Can you please send me full version of the following:
0300608 12/12/2008 Drive shaft
MTIP-08-12-6 12/01/2008 intermittent beep (high pitched sound) coming from dash ???
0104408 09/08/2008 Remote start (I can start car remotely from inside but it runs for less than a min then shuts off) ???
I have alot of vibration in my steering wheel and my mechanic - who drove the vehicle- said it is the drive shaft so I am having it replaced. My car does not pull right / left so the alignment appears fine, tires are new / balanced, brakes/ rotors are new.
He did see the TSB on the drive shaft and showed me what the bulletin stated.
I sure hope after replacing the drive shaft it goes away.
2008 List: (lemme know if any full version is needed)
Number Date Title
0501210 09/30/2010 A/T - Cooler/Line Flushing Procedure
0103510 06/02/2010 Engine Controls - Cold Engine Ping/Spark Knock
0400310 05/27/2010 ABS/TCS - DSC Activation On Low Speed Turns
0907409 11/13/2009 Navigation System - Service Information
0400609 06/02/2009 Brakes - Noise/Judder/Dragging
0903308 10/03/2008 Interior - Paint Peeling From Arm Rest Garnish
MTIP-07-10-2 07/01/2007 Collision Avoidance - Blind Spot Monitoring System Intro
2007
Hi! helbigtw, can I get the a copy for these tsbs,, MTIP-08-05-3 05/01/2008 A/T, 0200609 06/22/2009 Suspension, 0905609 10/07/2009 Body, 0900511 02/07/2011, 0400611 04/15/201, 0200411 07/11/2011, 0400711 10/17/2011 and 0500411 06/21/2011. Thanks!
