Another nice video. Making the bracket would be a problem for most of us. The oil in intake manifold is still excessive to me. And hopefully you’ll report back how much blow-by gas and oil will be collected in your catch can in the near future.Hi guys , would like to share another video for our Mazda CX 5.
This application will be suitable for the right hand drive only.
I don't think anyone proved or disproved it. There is also a chance that it makes carbon buildup worse.Is there any proof out there that a occ actually reduces carbon buildup on the back side of valves?
When you see how much blow-by gases and oils been intercepted in the catch can (i.e. Chris_Top_Her), you should at least feel better. Or those gases and oils will be suck into the intake manifold and should contribute the carbon deposit on the intake valves in theory. I can’t see there’s any way the oil catch can would make carbon buildup worse though.I don't think anyone proved or disproved it. There is also a chance that it makes carbon buildup worse.
That is my thinking on both those points.There was some discussion about oil catch cans for the CX 5 turbo on the BITOG Forums recently. I tried to find it again and provide a link but didn't have much luck.
Anyway, one person commented that the design of the Mazda Skyactiv engine was such that it wasn't necessary. I would do some further research before adding what may be an unnecessary accessory to my car.
I find it easy to remove that is y i choose this area for mounting location.Great video! But the location seems to be a pita to drain
With all the oils we’ve seen in the manifold when Felixd took the intake manifold off twice, apparently the factory “catch can” didn’t do a good job to catch those blow-by gases and oils.It might make it worse if the catch can acts as a cooler or moisture condenser and by the time the waste reaches the valve it is too cool or wet to burn up completely. I think Felixd will be able to show results which will be extremely interesting.
IMHO, seeing some oil in the OCC does not prove that it works well.
Does it improve 0.01% or 99.9%?
Maybe I will ask Mr. "Project Farm" on Youtube to do it....
This’s not true. Most blow-by stuff captured by catch can is dirty oil. Just ask Chris_Top_Her, but the pictures he posted were gone after our server upgrade. Actually you can see 2 videos felixd posted how much oil found in the intake manifold which could be collected by the catch can.The majority of what is captured by those cans appears to be water, either slurried with the captured oil or still separated.
