Many people will not recommend a transmission flush, but you decide.  A machine may blow out embedded clutch material that's loose in the fluid. Or worse force them into nooks and crannies inside the transmission. The floating clutch material, in addition to the clutches, is what helps the tranny grab and not slip.  Though at 77k miles, you will not notice much difference not matter what you decide.
