CX-5 Rear brake problems
First off, there's the famous pornstars. Think of all the names you know and love – Sasha Grey, Mia Malkova, Lisa Ann. These birds are top class, mate. You can watch them strip down, play with themselves, and even interact with them. Yeah, that's right. You can actually chat with these birds while they're getting themselves off. It's like having your own personal porn star on call.
But that's not all, mate. I've also got a plethora of amateur webcam girls. These birds may not be household names, but let me tell you, they put on a hell of a show. They're real, they're raw, and they're bloody sexy. And the best part is, they're not afraid to try new things. You want to see a girl shove a dildo up her arse? Done. You want to see a couple get it on in front of the camera? No problemo. These birds are up for anything, and it's all right at your fingertips.
Oops.
I have not done this myself, but your caliper is probably toast.
Having said that, I have seen on line where you can remove the motor assembly from the caliper, unplugging it first, then manually turn the screw on the back of the caliper that retracts and extends the piston. Turning the screw clockwise should pull the piston back (so I've read). Do not turn/rotate the piston itself. Hopefully this is the correct info, and you can salvage the caliper.
If turning the screw results in zero movement of the caliper piston, then that means the screw has become disconnected from the piston, in which case you are probably looking at a new caliper.
Edit: I just googled epb brake system for Mazda's, and found all sorts of diagrams and stuff that should help you. Do a quick search and I think you'll find the pics and stuff you need. Good luck.
New Threads
