Creeking and squeekin again!!!
2003 MSP
Okay, well where to begin, checked some other threads but didnt answer my ?.
So a few days ago i noticed this weird creeking coming from the rear of my car. Cant tell if its the brakes or the suspension or the bushings or what. If you have had this problem you KNOW what i am talkin about. Its just best described as like walking on an old wooden floor and it creeks. Know what i mean? I also have the E bushings and this is not a clunk! Its something else or maybe you could compare it to when you put the ebrake on when u park and the car moves a little when you get out and makes a CREEKING sound. Sorry for the convoluded description. Any ideas?
omg i've been having the same problem for like 2 weeks now. it squeeks and i dunno what the fuk it is.
i know right, so annoyinG! What the hell is that, i tightened my Ebrake and it still does it. Its like a CREEk how else can i explain it.
yup, lube the bushings.
I've been too lazy to go to the dealer and I just get under neath and spray some wd-40 on them and let it sit overnight. Lasted a few weeks now.
I was just at the dealer for this very same problem, they changed the rear bushings again for new E's.
Problem solved.
Lube would have probably worked just as well.
i have the same problem too, my ex said it was my seat, it sounded liek it was comin form all over the place, grrrrrr
Hi,
Had the exact problem. Went to the dealer today, they loosened the bushings, slid them over, lubed the sway bar and put the bushings back on. The squeak is now gone.
My seat is also squeaking. You can really pin point it to your bushings when it is up on a hoist and you push on the sway bar.
reviving an old thread with the same problem. My entire *front* end creeks when I go over something like a speed bump and it's not even below freezing yet. And it's really loud too. Not like grinding but like rubber which is rubbing against rubber when it's too cold (probably exactly what it is too). This is the first winter I will have driven the car, and I'm affraid it will only get much worse (Wisconsin winter = frozen balls...snow balls that is).
Anyone know A) if this can be remedied with said lube, and B) if so, where/how?
Thanks.
yea... same deal here... just started getting worse the colder it gets outside. I was first thinking struts. But I really dont know a s*** ton about specifics. I was just going to take it to the dealer with a few other minor problems.
