Have you pics of how you cut the 626 valve cover?
So I spoke with the shop again (http://candcperformancefabrication.com/ ) since I've been nagging for an update.
Cylinder head was sent WAY off cape to somewhere in Western mass.
(monkey2)
That shop is doing the decking, valve and valve seat work.
They finished the intake side so far. So about halfway done before it comes back for the port work.
The valve and seat work apparently / obviously also affects lift which affects our lash measurements.
Let's talk about what I am learning regarding lash...(ughdance)
Apparently aftermarket cams often CANNOT be set back to OEM tolerances.
This race shop uses a technique of trimming the valve stems along with shimming (I assume) to adjust lash.
Yeah, this way they can avoid the cost of those shim kits^^Interesting. I wonder if that's just because they don't have the amount and variety of shims that a Mazda dealership might/should have.
So with the fatter cams installed, is the valve lash too tight now with your original shims?
Please help me find and re-post these.The cams are not designed to operate with OEM lash though.... and no attempt should be made (especially on the exhaust side, which has a deliberately reduced (????) base circle) to get them to OEM lash specs....
The lash figures you are after are in the original GB thread and in the install thread
- if you go for OEM lash you'll be miles too tight....New lash numbers were worked out by the cam manufacturer taking into account the new ramp rate (which is very aggressive compared to the OEM cams) and base circle diameters...
also - have your head guys considered making custom shimless buckets? might be something to consider - less mass in the valve train etc - meaning less flogging the springs, less parasitic loss etc...
words...
twilightprotege said:LASH (important).
Intake should be set between 0.010 and 0.014
Exhaust should be set between 0.020 and 0.024 please note this is perfectly fine when you check your lash. If youre wondering, the reason for the higher lash is to get the ramp rates back into an acceptable range.
