could flash help my 4th to 5th gear shift problem?
ttlkaos
03 Black Mazdaspeed
Okay, i've been reading about the whole flashing the computer deal and now my question is... my car will not shift from 4th to 5th over like 90 mph (dunno) . i'll take 4th up to like 100 and try to shift, won't go, as the car slows down to around 90, goes right in like a slut. i've asked car buffs and people with more car knowledge, they have all told me that it's the computer. they've been with me when i've tried. so if i flash my computer, could that possibly reprogram the shift points on my computer?
the re-flash doesnt have anything to do w/ shift points..it just advances timing.
sounds like you have a problem there. Theres no reason why you wouldn't be able to shift. It is definetly not computer controlled.
when i try to shift, it doesn't grind, it doesn't feel like it's hitting anything to make it stop from shifting...in a weird way of explaining it, it almost feels like i don't have enough strength to make a full shift. now if that's the problem, i need help
have you had the transaxle removed and torn apart? if you have sounds like a misaligned part in the gearbox or loose or bent part in the shift linkage/fork
There in lies the problem.
your computer has little to do with s*** in the tranny.it sounds like a bent shift fork.maybe you have been shifting to hard?
i don't think i've been shifting to hard, i went the first 1000 miles without running the car hard for the breakin period, but right when i hit that 1000 mile number, i hit it and that's when i found out about the shift problem. i don't know much about the transaxle or shift forks, but why can i shift normal anytime but around 90 mph. if it was bent, wouldn't be a pain in the ass to shift all the time??
Take her in to Woodhouse Mazda. Only MAZDASPEED authorized dealer here. Talk to Jaime, he is a cool guy.
see above
it's got to be a shift fork.
it's not a synchro or blocking ring,or even the dog teeth cause any of those would causeggear clash.and since it's not affecting any other gears it's not a linkedge or alignment problem.
