Replica said:How is a supercharger any different than a turbo when adding it to an N/A build? Both raise cyl pressure and intake temps...that is the nature of FI.
Brian MP5T said:Run a 7 PSI turbo setup. It will be $3000.00 or less and will get you much more in HP than any NA build for double the cost that you can come up with...
Brian MP5T said:It is ture Josh... You know it...
Gen1GT said:Everyone's probably going to pass me in the performance department this summer. My girlfriend and I are getting a place together this summer, and there'll be the requisite furniture and renovations going on. She doesn't have a car right now though so she'll be getting the 1990 GT.
It's all good, I'll still try and keep everyone competitive. 3 for sure mods are the custom header, exhaust cut-out and drag tires(and some new Azenis for AutoX).......
I think once Scorch gets his setup finished, he'll be the benchmark for the NA Protege crowd though...you know what engine management you're going with yet David?
Gen1GT said:Come on David...spend the money on IRTBs instead of Nitrous. You'll have one of the most powerful Proteges AND the best sounding!
You'll easily gross 200 crank...Paeco headwork is your trump card....
Super Matty P said:Scorch, how's your build coming. I remember speaking with you about it a few times. Like I told you on the phone. Paeco is only about 20 minutes from my house. I've spoken with them a few times about having work done but decided against it since they never give you a set time frame of when the work will be complete. If for some reason you need to get in touch with Paeco and can't let me know and I'll see if I can help.
p.s. as for the design difference of cams for NA engines and turbo engines there are HUGE differences. Stock cams seem to do well on simple low-boost turbo kits but having a set of custom ground cams designed specifically to optimize turbo spool-up is a HUGE gain. Trying to argue this fact will make anyone look stupid. Maybe you guys should ask Wagner. He's the only person in the protege community even working on cams for our cars. He's working on two sets...NA and turbo...maybe there is a difference afterall.
SpicyMchaggis said:Don't listen to josh. Ever. Go spray or go boost. Don't do N/A. It's a lot of money and is not worth it at all.
Gen1GT said:Kyle, don't be mad because my car can run at redline around a long sweeper without blowing up or having any sensors fail.........
........that's right, I went there. (dance)<----favorite smiley thingy....
