Cooling fans not engaging
Dvdap
Mazdaspeed Protege 2003.5
i have two ebay slim fans mounted to my mishimoto rad, however recently my hot pipe melted my ac cooling fan so now i am down to one.
After it melted the other fan will not engage, causing me to overheat in stop and go traffic.
what all should i check besides fuses,and how do i check the fan relays with a multi-meter
Thanx
ohk i will check, however the fan that did not melt is the one not working
I don't believe the fans in your car share any portion of wiring from the factory, however I have no idea how your eBay fans are wired in. Is it possible they are wired in series?
The easiest way to test a relay without any knowledge is to swap it with another one in the fuse block and see if the fans suddenly work.
