coolant elbow??
mazdarally02
2002 mazda protege 5 speed
ok so i own a 2002 mazda protege 5 im putting the factory mazdaspeed protege turbo with all the OEM lines and fittings.the stock manifold and s-pipe the problem im have is where does the coolant feed go and where does the coolant return go? i have all the facorty hard pipes on the turbo and the factory three way elbow mazda uses. i need help pictures would be great if someone can show me how the elbow is ran and installed with all the lines installed in it. and how the feed line is installed thanks
