ELEmental59437
- 2002 P5, 1978 F250
Hey man, the radiator looks beautiful, hopefully we can get this situated before we leave for the meet. GOOD LUCK!
Nope, it was the Mazdaspeed 1.3 BAR cap for the Manual transaxle Proteges. Not sure why the caps are different for the automatic Proteges. I now have the Mazdaspeed 1.3 BAR cap for the automatic Proteges. You can distinguish between the caps by color. The 1.3 BAR Mazdaspeed cap for the Manuals is Green. The automatic cap is Pink.jrodhotrod said:hmmm..... My turbo outlet pipes are already really close to the fan on the passenger side, I wonder if they will still fit with this rad.
Was your cap a stock cap? Kind of a surprise that it doesn't fit. I guess I should check mine before installing it.
Yep. 1.1 BAR = 16 PSI (15.9 PSI)StuttersC said:OOOH, so I probably do need a cap then...
After talking to a source of mine, I found out that the reason for this is that they used the Calsonic cap fitting on this radiator. They need to use the Denso cap fitting for the manuals. I need to inform Anthony of this in the A.M.LinuxRacr said:Ok, yall are never gonna beleive this s***, but the radiator cap that fits on the automatic Proteges worked! :wtf: Moeed got it from Pirana, and dropped it by. Thanks all, now to fix my overflow nipple problem tomorrow.
Gald I ahevn't orderer my cap yet.LinuxRacr said:Yep. 1.1 BAR = 16 PSI (15.9 PSI)
Oh yeah huh...Man I need sleep.LinuxRacr said:Well about what cap you get, it depends on what fitting they used for yours. Denso or Calsonic? Go test your radiator cap asap, and then you will know.
And we love you!!LinuxRacr said:I am the site guinea pig. Don't you know that by now?![]()
Well, just know that at the same temperatures with the AWR Radiator, the temps were from 167-176 while cruising at the same speeds! That's like 20 degrees cooler!Tonight, the temp outside was 74 F, and while driving into work, my coolant temps were around 180 when I 1st started driving. About 30 miles later, I started noticing that my coolant temps were around 190-194. This was at night. If my coolant temps are that high now, just imagine when summer hits. (nervous)
