I came up with a way to modify the stock, aftermarket, or pretty much any compressor housing out there. Im seeing if anyone is intersted in having this done. If so, I would like to start a list of who's interested. I would need at least 10 people for this to be worth it. Right now the pricing should be around $130-$150, that's including the return shipping.
(I still need to sign up to be a vendor, will do ASAP)
What i do is take the stock (or aftermarket) compressor housing on pretty much any size/type of turbo and increase its air flow capabilities. I do this by adding as much taper as possible to increase the velocity action of the housing. Not only does the taper greatly increase the turbos capabilities, but the inlet itself is opened up for a larger intake area. I smooth all edges to let air flow as smooth as possible. The entrance edges are also narrowed as much as possible without hindering there strength. This give the air flowing through your intake less turbulance when entering the turbo. The inlet is also polished to a smooth finish to finish off this nice upgrade. and it looks cool!!!
Talk is cheap....
Holsett HX40 before (with anti surge housing)
and after:
GT28 before (from fatti03MSP)
and after:
Talk is cheap....
and after:
and after:
