Looking like a Monday release guys. We can't release on a Friday and there was more testing necessary than usual. We've moved over to a new code repository system since the last release so the developers wanted to do a higher degree of testing than normal to verify everything was working as expected. Don't want to grenade any ECUs.
Here is a sneak peek of the release notes:
New Features:
•Tuner Auto Updater
•Users can accesss tuner software updates through the "Help/Updates" menu.
•Users will no longer have to download the latest tuner version to stay up-to-date.
•Rollback - users also have the ability to rollback to the previous release of Tuner by using the "Help/Updates/Rollback last update" option.
•Added <acronym title="Cobb Access Port">AP</acronym> MGR 2.0 Installer
•Added HPFP Control Tables (BETA)
•HPFP Desired Pressure - Max A
•HPFP Desired Pressure - Max B
•HPFP Desired Pressure A
•HPFP Desired Pressure B
•HPFP Desired Pressure C
•HPFP Desired Pressure ECT Comp
•Added Knock Tables (BETA)
•Knock Retard - Decay Magnitude A
•Knock Retard - Decay Magnitude B
•Knock Retard - Decay Rate A
•Knock Retard - Decay Rate B
•Knock Retard - Multiplier
•Knock Retard - Offset
•Knock Retard Active - Min ECT
•Knock Retard Active - Min Load A
•Knock Retard Active - Min Load B
•Knock Retard Active - RPM (Max)
•Knock Retard Active - RPM (Min)
•Added Radiator Fan Tables (BETA)
•Radiator Fan - ECT Thresholds
•Radiator Fan - Voltage Compensation
•Added MAP Sensor Scaling Tables (Sesnor Cal. Tables)
•MAP Scalar for EM - Component A
•MAP Scalar for EM - Component B
•MAP Scalar for EM - Offset
•MAP Scalar for Log - Component A
•MAP Scalar for Log - Component B
•MAP Scalar for Log - Offset
•MAP Scalar for OBD - Component A
•MAP Scalar for OBD - Component B
•MAP Scalar for OBD - Offset
•Added Ignition Compensation Tables
•Ign BAT vs ECT Comp. - % Used
•Ign BAT vs ECT Comp. A
•Ign BAT vs ECT Comp. B
•Ign Low Octane Reduction
•Ign Per Cylinder Comp.
•Increased Boost Pressure Logging Limit
•Increased limit to log boost pressure above 24 PSI.
Bug Fixes:
•Fixed MIL Defeat
•MIL defeat implementation has been corrected for 06-07 <acronym title="Mazdaspeed 6">MS6</acronym>, 07-08 <acronym title="Mazdaspeed 3">MS3</acronym>, and 09 <acronym title="Mazdaspeed 3">MS3</acronym>.
•See "Edit\Advanced Engine Parameters\Toggles(Base)" for complete list of defeatable codes.
•Fixed Live Tracing
I also added toggled to enable individual cylinder ignition compensation.
A toggle is available to switch the ECU from using the Load Dynamics table to instead use the Boost Dynamics table. What this means is instead of the ECU tweaking the WG Duty cycle based on Load Error (difference of Desired Load against Actual Load) it will instead control the turbo based on Boost Error (different of Desired Boost against Actual Boost).
Finally a toggle is added to activate the Load Target table. This just enable a more simplistic Load Target functionality for the ECU so instead of using all the various potential gear based and other logic driven Load Target tables it simply pulls the target from the single Load Target table and runs with it.
Both those toggles have been added to assist you all with stable boost control. Of course you don't need to use them and the system will continue to operate 100% as before.
Cheers,
Trey @ COBB
With ATR you can callibrate your MAF to get your fuel trims within range. I know it's a lot but the pdf on ATR would help a lot, have it on hand. You can spend as much time on tuning as you'd want to i promise.
I need some advice on an economy map for my mods, the econ map on the AP is for stock. Any help?
why not just copy your maf tables over to it
I'm gonna spend some time today making sure all the hose clamps are on good and tight. If I don't find any leaks, then I will look at the boost tables and see about raising the boost a little (1-2psi). LC is great. Its hard on the car, but it really makes launching the car a breeze. I need to play with the FFS settings, I don't think I have them right. I think I need to increase the Vehicle Hysteresis (sp?) Speed. I currently have it set at 6 or 10 mph, but I think I need to set it much higher, faster than the car will go, to make it work at any speed. Lots of reading for me today.
BTW, I got ATR from Cobb yesterday evening.
FFS Rev Limiter: 4600rpm
Launch Control Rev Limiter: 4100rpm
Normal Rev Limiter: 6700rpm
Speed Limiter Hysteresis: 4mph
Vehicle Speed Limiter: 10mph
These are settings i'm using for LC and FFS. You have to set the VSL low so you don't get limited by the launch control rev limiter in first gear.
I got it working. Also updated the map I am using and the one you use to idle @ 900. Mad three versions of each map. one with a more aggressive LC, one with a lower LC setting and one with no LC at all. Have not had much time to mess with it because I have been running around all day with the family. I may go for a drive shortly to play with the settings. I will load all the maps on the AP before I give it back. BTW my mind is made up, I want an AP for sure. ATR makes it such a powerful tool. I am barely scratching the surface and I love it. It really appeals to the geek in me. So much to learn, so much potential.
