Clutch Switch Input Circuit Malfunction P0704
I have heard good things about Exedy. I had a Spec Stage 3 Hybrid and it didn't work out for me. There should be quite a bit of info. on this topic here, if you do a search.
wow, I didn't know the computer was so smart it knows when your clutch is burned out! :rolleyes:
You do know that you just need a new clutch cut switch not a new clutch right??? I have the same problem on my car and thats all it is. When you look up from the bottom of the car at the clutch pedal you will see 2 switches and it is the one that is closest to the driver seat, not the one by the fire wall.
