lordblitzalot
i have a 1989 mazda 626 4 cyl fi
just the other day i noticed i had alot of play in my clutch it goes down to about 3 inches from the floor before it starts getting any tension at all.
so today i figured i would try to bleed it and add a little more fluid and now i do not have any clutch it just goes all the way down to the floor and doesnt pop back up.
if i sit there and pump it really fast with my hand for about 3 minutes it will start building pressure and i will have a clutch again but then after a few minutes back down to nothing.
i was thinking it was either the master or slave cylinder are going bad and maybe leaking internally (there are no fluids leaking out of it and it was full)
does anyone have any other suggestions, or could i be on the right path?
if it ends up being the clutch itself i will probably junk the car but if its an easier fix i will end up keeping it.
any info would be great
