I think we've identified the problem heretothepunk said:i just lowered my 02 p5 with skunk2 coilovers......for some reason out of no where....the front started to make this clicking sound when i turn the wheel left or right...does anybody know what it might be and how to fix it??
AznXstazy said:ya, mine stopped as well.... it does it from time to time now.... i think it might be the tie rod end bushing... cuz its only when i turn... and it sounds like its coming from the knuckle. are you lowered?
blackdragon11 said:mine is lowered with the Skunk2's as well, the popping noise comes from the spring rotating when you turn, the metal to metal contact between the spring on the top perch is what makes the noise. I am going to be making some polyurethane mounts to slip between the two fronts on mine to rid of the noise.
