Clicking Clutch Problem- Help!
Joe PR5
My Clutch has a clicking feel and sound.. I brought it in, they said the replaced a spring, it felt good for about 5min, then the noise and feel is back, anyone know what this is? Im bringing it back next week. I have 40,000 on my car
i hear a rumble/grumble/something at approx1800-1900 rpm when im acceleratin slowly, that what u hear?
No its when im not even moving or if i am moving, when i press down the clutch , its not one smooth movement, its click-click and the same noise when i depress it.. I have spoken to some people, It may be the throw-out bering, or a bad hydrolic line? Just seeing if maybe someone else has had this problem fixed..
Do you know how much they cost? what kind are people getting? Do you know what would make one better than another?
i have exactly the same problem as joePR5. mine happened after I got the hotspot clutch fix by the dealer.
my mechanic friend said that its caused by the spring clicking. I've taken it into the the dealer and they said that nothing is wrong with the spring clicking either.
so its your call if you want to fix it or not.. I know it feels like s*** when you press the clutch cause you can actually feel the click...
Keep taking it back until they fix it. You are still under warranty. No need in spending more of your own money on the car if they are taxed with fixing it.
