Cigar Lighter Problem
GeorgeJ
I have a 1999 Mazda Miata. The Cigar Lighter does not work,So I checked the Power Outlet with a Meter and get no Current.I have checked all the 15 Amp Fuses and nothig is blown.Any one out there can help with this problem.GeorgeJ
did you buy it used?
try to find a manual that will point you in the right direction as far as fuse location. Just because it is supposed to be a 15 amp doesnt mean that someone didnt replace it with a 20 or some other random amp fuse. So if you have no manual...start checking them all
